Old 09-19-2014, 04:36 PM   #1
sixysixss
Door Triggers/Switches
I am getting ready to install an alarm on my 66 GMC. I need to install door triggers. While I'm at it I'm going to wire the dome light into the triggers as well. I'm sure people have installed triggers/switches before. What is the easiest way to get it done? Photos would be great. It looks like it may be easier to put the switch in the door rather than the cab. Has anyone tried that? Let me know what you did. Thanks.
Rob
1966 GMC 1500
sixysixss is offline   Reply With Quote
Old 09-19-2014, 05:06 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Door Triggers/Switches
This is what I used...
napa has them in stock also
http://www.oreillyauto.com/site/c/de...0946&ppt=C0335
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 09-19-2014, 05:47 PM   #3
Woogeroo
dome light assembly : how to remove and replace?
scroll down to post #14.
-W
Woogeroo is offline   Reply With Quote
Old 09-19-2014, 10:02 PM   #4
LVPhotos
LVPhotos's Avatar
I think you can do the button contact style at rear of doors. Haven't looked in awhile about through the vent.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
