Old 09-19-2014, 05:58 PM   #1
61K10
61K10's Avatar
window regulator lower roller track
are 60-66 lower window regulator guide tracks the same? I have seemed to have lost mine in the build process. nobody repops these right? anybody have one that they can measure? I guess I'm lucky that's all i have lost in the 2-1/2 year build lol!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-19-2014, 09:52 PM   #2
LVPhotos
LVPhotos's Avatar
Re: window regulator lower roller track
26 X 2 in u channel. There is a left and right. But I had two lefts so I cut the "wing" off till I found a right. Guess it pushes on rollers
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-20-2014, 12:19 PM   #3
61K10
61K10's Avatar
anybody have a picture?
1961 chevy K10
Old 09-20-2014, 12:41 PM   #4
LVPhotos
LVPhotos's Avatar
Mine does not have wing on back. Call Tuckers Classic Trucks here in Henderson, NV ask for Tom. Might have some in used part pile. 702-258-1955. Monday.
Old 09-20-2014, 12:53 PM   #5
61K10
61K10's Avatar
LV--that is the track at the rear of the door that the window slides up and down in? I need the roller track that bolts to the door right under the big opening. I think it's the piece to the far left in this pic. one like that one bolts to the window frame also. that might be the one for the window.
1961 chevy K10
Old 09-20-2014, 01:13 PM   #6
61K10
61K10's Avatar
similar to the track on the bottom of this pic
1961 chevy K10
Old 09-20-2014, 02:24 PM   #7
LVPhotos
LVPhotos's Avatar
Got it. I left mine on so I wouldn't loose them. Still give Tom a call Monday they might have them. My trick is not to look for it and look for something else and it will show up.
Old 09-20-2014, 03:05 PM   #8
61K10
61K10's Avatar
LOLOLOL!!!! never mind. they are welded to the inner door and about 4" long-can't see in my old age---------
1961 chevy K10
Old 09-20-2014, 03:13 PM   #9
LVPhotos
LVPhotos's Avatar
Works every time. Lost a set of keys, had them in hand with other stuff. Lol
Old 09-20-2014, 09:48 PM   #10
61K10
61K10's Avatar
thanks LVPotos---for pulling my head out of----
1961 chevy K10
