Old 09-20-2014, 07:46 AM   #1
evan396
front end upgrade
my dad and i want to upgrade the front end of our 66 k20 to disk brakes. we got a newer front end from his cousin, and we are going to reuse the eaton rear. we want to know if we can switch out the gears from the the old one to the newer one,to keep the same gear ratio. ( if the gears are ok). and if we can do it. if not, can we get a gear set to match the rear. also would this be a good front end to use? thanks evan396Name:  IMG_0047.jpg
evan396 is offline   Reply With Quote
Old 09-20-2014, 10:57 AM   #2
ryanroo
ryanroo's Avatar
Re: front end upgrade
the older is a D44 and the newer is a corporate 10 bolt. the gears are not going to swap. the 10 bolt is a perfectly good axle. it is the same in strength as the d44. stronger in a few areas than a 44 of that age. the parts are easy to get and cheap. i would not have any issue running it. a person familiar with old chevy trucks would know it was not period correct, but that does not matter to me.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 09-20-2014, 12:41 PM   #3
61K10
61K10's Avatar
evan--is that a 3/4 ton front axle? the eaton probably has 4.57/4.56? gears. i don't think they are available (ring&pinion) anymore.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-20-2014, 04:01 PM   #4
evan396
Yes 61k10 it is a 3/4 ton front axle, and the rear is the eaton.you are right about the gear ratio, will double check to see which one we have. So ryanroo, we can use this front axle as long as we get a set of gears to match the rear? Thanks evan396
Old 09-20-2014, 04:11 PM   #5
jeffahart
jeffahart's Avatar
what gears you looking for. A have a eaton ho52 I'm about to scrap. It has 4.10. I can gut if you want. What's in the front you are swapping in.
jeffahart is offline   Reply With Quote
Old 09-20-2014, 05:13 PM   #6
evan396
Jeffahart, we are looking to up grade the front to disk brakes. The rear end is a Eaton Ho52, we are going to keep this one in the truck.we had the drums cut and put in new bearings and seals. Along with new brakes. The gears we are going to need would be for the front end to match the rear end. Thanks evan396
Old 09-21-2014, 03:34 AM   #7
argonaut
argonaut's Avatar
Evan, jeffahart is offering you the 4.11 gears for the HO52 because it may be more friendly for driving the truck than what you have now. You may still have to swap out the ring and pinion gears in the corporate 10 bolt either way.
Do you know what gear ratio your rear axle has now?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-21-2014, 10:17 AM   #8
farmallboy15
If you bought a later d44 71+ you could just swap the axle shafts, knuckles, hubs and brakes over to the housing on your truck (as long as your 44 is open knuckled). That's what I did on my '70. That way you don't have to mess with gear install.
farmallboy15 is offline   Reply With Quote
Old 09-21-2014, 05:36 PM   #9
evan396
OK so we went out and took off the differential cover on the newer Axel. It is marked Gm 3988515 10-4110-85. So we think it is a 4.10 made in 1985. So if jeffahart has a rear with a 4.10 for the Eaton, We should be able to just swap out the Eaton rear end.what would your opinion on these gears be argonaut or anyone else. we think this might be the easier way to go farmallboy15. Thanks for your help Guy's. Evan396
Old 09-22-2014, 02:56 AM   #10
andrewmp6
Gear ratio depends what tire size and trans your gonna run.
andrewmp6 is offline   Reply With Quote
Old 09-22-2014, 12:59 PM   #11
jeffahart
jeffahart's Avatar
I was the second and fifth owner of the this particular truck; and I have ran many miles with the 4.10s and 31s and 33s empty and hauling loaded and in tow. I love the 4.10, I think it's a good compromise for hauling and empty. In fact, I now have 4.56 in the axles I just swapped in and I plan to change them 4.10 when I can get a good price, as the 4.10 and 4.56 are on opposites sides of the carrier breaks for my d60 and corp14.
Old 09-27-2014, 10:23 PM   #12
jeffahart
jeffahart's Avatar
Evan, I dissembled the axles this afternoon. Here's pics of the 4.10s and the Eaton they came out of; and I was running both of those axles up to a couple months ago and they were fine. I could not get the nut off the yoke so the bearing is stuck on there. I could not find right socket in my tool box.
Old 10-17-2014, 12:49 PM   #13
jeffahart
jeffahart's Avatar
I located a 1-5/8" socket and got the nut off. Here's pics of the parts.
