is there a trick to taking out the dash cluster?
hey guys. I need to take out the dash where all the gauges are. is there a trick to getting it out other than taking out the front screws? I wanted to make sure there was no other hidden screws I didn't see before I try to continue giving force because its pretty stuck on there right now.
Thanks! |
![]() Join Date: Apr 2010
Re: is there a trick to taking out the dash cluster?
Lower the steering column down, unscrew the speedo, take oil line loose if you have a gauge cluster, unplug circuit board. take light switch knob off, wiper knob off and I think it will be ready to come out
The wiper switch has an allen screw holding it on and the light switch behind the dash has a spring loaded button to be pressed and then the knob and shaft pulls out. It just pushed back and will snap into place.
Old member
Speedometer cable has to come off the back of gauge, oil line taken loose. Unplug the wiring harness and lower the brake stop pad then take the c-clamp loose then the wiper and light knobs as stated and have the battery disconnected are you will run the battery dead. Then the front screws and it should come out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
As stated above are most likely the best steps to do so. As for me, I didn't do anything with the steering column nor the brakes, but I did do everything else mentioned.
Same with me, Low & Slow....there's enough room to tilt the cluster and get it out without dropping the column.
Steve McMillen ASE and GM certified Master Technician 25 years+ experience ![]() No, I do not know it all, that's why I attend tons of training. |
![]() Join Date: Aug 2008
Imo on the teucks i have worked on, you take a risk of damaging the printed circuit on the cluster by scraping it on the metal dash if you dont drop the column
I understand what you're saying, but the way I wiggled it out and wiggled it back in numerous times, not one scratch was put anywhere on the cluster or the circuit board. But yes there is that risk if not careful
i must be missing somehting here. the gauage cluster wiggles on the bottle,half but the top still feels like there is some sort of bolt holding it in still. i cant even stick a flat head to try to pry it out. its still on there pretty tight
so i take that back. now its all making sense. the only thing I am having a problem with now is the light button. I was able to pry the 2 clips on the housing of the light off but can't seem to get it completely off?
there's a ground wire from the cluster to the firewall that needs to b removed too
#13 |
Old member
You have to take the nuts from around the wiper and head light switch loose also up top. The column not being droped is OK for a non gauge cluster but for a full gauge cluster you best drop it. It will scratch the paint up and the cluster if not very very carefull. The brake plate is the flat plate the brake pedal rest on with the rubber bumpers. Yes there is a ground wire also on some models I have seen them with and without it. If it has the factory tach you have that connector also on the back to unplug.
#14 |
Andy is correct. You have to get a bit creative if you don't have the proper tool to take off the bezel type nuts that hold on the wiper and headlight switch. They are round and chrome and have two slots in them for the tool. I think I used two small screwdrivers and clamped them together with vise grips then used a bigger driver between the two to turn them. they can be on there pretty good sometimes.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#15 |
so finally the cluster is free but i have one small,issue...and that the lights and,choke,knob. do i pull the knobs off? i gave it a good amount of force trying to pull off but it doesnt look like it comes out that way.
#16 |
Why not drop the steering column? It's eight bolts/screws and takes about three minutes.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#17 |
![]() Join Date: Oct 2011
I've got a set of very detailed pdf instructions that I did up on how to do this and re-install if anyone is interested.
Includes a tool list and 'watch/gotcha' points. Total time with practice....about 15 minutes...fully removed, no damage. Installation time...bit longer, particularly if the new unit has a tach on it and YES...you have to drop the column...BUT...you don't have to fully remove the 5/16" bolts holding it. All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#18 |
#19 |
If you have the cluster out, what knobs? Can you post a photo?
#20 |
this one..
#21 |
'Everything is out'....do you mean everything to your knowledge is 'undone'? or have you removed the gauge cluster?....or? not clear here.
Therefore: Headlight Knob: reach up high under the dash with your right hand and located the (inner) headlight switch assembly. -Use your index finger to find a 'springy' button on the top of the switch assembly (you don't have to see it.... to find this with your finger). -Depress this button and pull the switch straight out while you are doing so....wiggle a bit if necessary. Wiper Knob: 'look' around the inner circumference of the black plastic knob to locate a very small set screw. -Use a small slotted screwdriver to back out this screw and release the knob off the wiper switch/shaft. That should be it....if there is something else keep us posted (note: to drop the steering column you need a 1/2" socket with a 3" extension and a driver to nearly fully loosen to bolts that can be see from below when you look up at an angle from the lower seat area.) Coley
#22 |
What Coley said...
Headlight Knob: reach up high under the dash with your right hand and located the (inner) headlight switch assembly. -Use your index finger to find a 'springy' button on the top of the switch assembly (you don't have to see it.... to find this with your finger). -Depress this button and pull the switch straight out while you are doing so....wiggle a bit if necessary. The rod that the knob is attached will come out.
#23 |
Yeap, that light switch knob kicks everybody's butt the first time. Disconnect your battery, in order for you to pull the knob and shaft all of the way out, you first have to pull the knob out to where your headlights would be on, and then press the spring loaded button and pull the rest of the way out.
#24 |
Good info for future use.......
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#25 |
Old member
You have to reach inside of the dash from the underside and the body of the switch has a spring loaded button you have to push it in while pulling the knob out the whole thing will come out stem and knob. It has to be done together.
Also the best tool I have found for the washer nuts is a set of niddle nose pliers. They work great for this. ![]()
