09-20-2014, 02:13 PM | #1 |
Blower motor keeps burning out
I have replaced the AC blower motor three times. On each occasion I would smell something burning in the AC vents. after about three hours of runtime the blower motor would just give up.
Any of you guys know where I should start first ? what could be causing the blower motor to burn up?
09-20-2014, 04:27 PM | #2 |
Re: Blower motor keeps burning out
Did you replace blower motor resistor?
09-20-2014, 06:24 PM | #3 |
No, I have not replaced anything other than the blower. The speeds hi, med and low all work as they should. Think it may be worth a shot to just replace resistor anyway?
09-21-2014, 09:59 AM | #4 |
BAD BOW-Silverado XST
Check the fan ground. It may not be grounding properly.
09-21-2014, 10:51 AM | #5 |
Are you getting the motors from the same place? It is possible they have a bad batch. If these are all warranty replacements from the 1st one, verify the initial sales person pulled up the correct part number.
Check the voltage the the motor with the fan switched on. |
09-21-2014, 11:53 AM | #6 |
Moderator
Make sure the blower motor is getting a good ground. My 75 had a braided strap from one of the retaining screws to the fender.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
09-21-2014, 09:45 PM | #7 |
My 83 had the same setup. It went out just like the OP said, and all I had to do was clean up the ground and it worked great. Replacing the resistor is a good idea anyway, it's like $10.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
