Old 09-20-2014, 05:55 PM   #1
semocoachworks
semocoachworks's Avatar
Lockout Info
Anyone know who made these lockouts? Says hub look on face.
69 C20 Suburban 4x4
37 Plymouth Sedan
58 Dodge PowerGiant
96 Suburban
83 GMC 2500
12 Malibu LTZ
semocoachworks is offline   Reply With Quote
Old 09-20-2014, 06:09 PM   #2
vectorit
What?
vectorit's Avatar
Re: Lockout Info
Those are "big hub" Dana Spicer, they were phased out in late 1969.
Finding parts for them are a bear...
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-20-2014, 06:20 PM   #3
semocoachworks
Re: Lockout Info
Thanks Vector it. When I bought the suburban it had sat for a while and they were hard to turn. I took them apart and cleaned them up good and now they work well. I like the originality but I am eventually going to swap the HO52 and the closed knuckle 44 with 4.56 gears for a D60 and 14 ff with 3.73 or maybe an NV4500 with 4.10's. I just need it to get through this winter. Thanks for the info.
69 C20 Suburban 4x4
37 Plymouth Sedan
58 Dodge PowerGiant
96 Suburban
83 GMC 2500
12 Malibu LTZ
Old 09-20-2014, 07:24 PM   #4
vectorit
What?
vectorit's Avatar
Re: Lockout Info
There is absolutely nothing wrong with those hubs, they are tough as nails and take a lot of abuse. You did the best thing one can do, and that is to clean them and lube them. Since they are old, the grease gets petrified. Which makes them hard to operate, and also causes them to fail when being used.
They will definitely last you another season now.
Too bad you are so far away, since I'd be pickin over those old axles for little bits of parts I need after you swap them out.
When you do take them out, save the 3rd member and the axle shafts of the H0-52 since you can sell them easily. The axle itself is big and heavy, and not many people are interested int he whole assembly.
The front axle, I'd save the hubs and the drums.
The new replacement drums are garbage.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-20-2014, 07:33 PM   #5
semocoachworks
Re: Lockout Info
I am moving to Springfield MO this spring or maybe sooner. Wouldn't be much closer I guess but I will definitely let you know when I do the swap. All the front axle brake components and hardware is in good shape. I love this old thing and will drive it for a long time, it would be nice to be a little more highway friendly. It has manual everything and honestly steers and handles like it has power steering. I lurk here a lot and read all the time. Just figured its time to think about getting it upgraded.
69 C20 Suburban 4x4
37 Plymouth Sedan
58 Dodge PowerGiant
96 Suburban
83 GMC 2500
12 Malibu LTZ
Old 09-20-2014, 07:53 PM   #6
vectorit
What?
vectorit's Avatar
Re: Lockout Info
Glad you opened up a thread about an often overlooked part that is very important on these old K20's.
My 1968 K20 Suburban is manual everything as well, and you are right they do handle very nice. It's just the parallel parking that gives you a work out!
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-20-2014, 10:36 PM   #7
semocoachworks
Re: Lockout Info
My cj7 is manual as well and this suburban is like a Cadillac compared to the jeep.
69 C20 Suburban 4x4
37 Plymouth Sedan
58 Dodge PowerGiant
96 Suburban
83 GMC 2500
12 Malibu LTZ
Old 09-21-2014, 10:15 AM   #8
Cobalt964ruf
Cobalt964ruf's Avatar
Re: Lockout Info
once you do the axle swap I would be interested in the d44 manual hubs for my 71 k20.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
