Old 09-20-2014, 10:00 PM   #1
texasld
texasld's Avatar
Remove Transmission crossmember "upper brackets"?
Is it possible to remove them and keep them out. They are in the way for where I would like to run exhaust. Will it be structurally unsafe, or can I ditch them?
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 09-20-2014, 10:29 PM   #2
Xeen
Xeen's Avatar
Re: Remove Transmission crossmember "upper brackets"?
You can ditch them.
Most aftermarket transmission crossmembers only use the bottom mounting location.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-21-2014, 08:55 AM   #3
texasld
texasld's Avatar
Sweet! I figured as much. Thanks for the response, Brian.
1999 Jeep TJ
