Old 09-20-2014, 10:34 PM   #1
Chevys10dr
Chevys10dr's Avatar
12 Bolt rear end saddle angle
Hey guys,
Hoping someone can help me out, I'm switching over from leafs to trailing arms, the rear end I have is setup for leafs, I need to weld on trailing arm saddles, what is the angle that they are welded on or are they parallel to the yoke?
Chevys10dr is offline   Reply With Quote
Old 09-20-2014, 11:09 PM   #2
Zeroman
Zeroman's Avatar
Re: 12 Bolt rear end saddle angle
I've got a differential sitting in my garage that I am rebuilding.
It is not parallel to the pinion shaft. The saddles tilt downward towards the front of the truck.
Not sure how I would measure the angle.
If someone could tell me how to measure the angle, I'd be happy to tell you what it is.
Zeroman is offline   Reply With Quote
Old 09-20-2014, 11:25 PM   #3
mechanicalman
Originally Posted by Chevys10dr View Post
Hey guys,
I believe parallel. I would assemble it without welding, with the truck fully assembled with bed on and at operating weight, and at the suspension height you intent to leave it. Then rotate the pinion parallel to the trans output shaft or carrier bearing then weld it in that position. Of course make sure the panhard bar is in place and that the rear-end is centered in the truck to your satisfaction. (you might have to use a bottle jack and a mallet or get creative with a come-along).
I have never done this before, just thought about it. I would for sure defer to more experienced fabricators on this forum and use my advice, in this case, as a last resort if nobody else replies.
mechanicalman is offline   Reply With Quote
Old 09-20-2014, 11:50 PM   #4
Zeroman
Zeroman's Avatar
mechanicalman, I think his question was concerning the saddles on the axle tubes, not the pinion angle.
Here is a pic of my differential I am rebuilding. You can see the pic is taken directly over the pinion shaft which is pointing straight down, and the saddles are tilted down towards the front.
[IMG][/IMG]
Old 09-21-2014, 12:48 AM   #5
mechanicalman
[IMG][/IMG]
My bad, I thought he meant pinion angle parallel to the yoke of the trans, as the goal of getting the brackets at the right angle is to achieve proper pinion angle as parallel to the output shaft location (see picture). Maybe I should have started on a more basic level so here goes.
Getting back to the brackets, they need to be installed at an angle to get the drive-shaft correct, and that means the pinion needs to be parallel to the trans output shaft or primary drives-shaft if a 2 piece shaft. When I said assemble it without welding, I meant put the brackets on the axle shafts without welding, then rotate the pinion to the proper angle (see picture). The panhard bar is going to center the rearend, but best check placement before welding in case something needs to be done to the panhard bar and that depends on ride height (unknown factor).
The angle of the brackets vs the angle of the pinion, by itself without respect to the drive-shaft angle, is a crude method at best. The best he could hope to do is to try to get close to what you have, and that might not be right for him depending on his drive-shaft configuration and ride height.
If he welds them on wrong resulting in an improper driveshaft angle, he can get a custom adjustable cross-member or shims between the brackets and the trailing arms to correct it.
Old 09-21-2014, 01:01 AM   #6
Chevys10dr
Chevys10dr's Avatar
Thanks guys, I was hoping there was a factory placement angle, so that I could weld up and install, the setup I am using uses the stock setup and no pinion angle change needed.
Old 09-21-2014, 01:19 AM   #7
mechanicalman
Good luck, have fun, and stay safe.
Old 09-21-2014, 10:28 AM   #8
Zeroman
Zeroman's Avatar
mechanicalman, your explanation is spot on in regards to setting the pinion angle.
Chevys10dr, I am going to set up my diff with some magnetic mounted levels later today, and should have a stock angle for the saddles.
Old 09-21-2014, 10:57 AM   #9
Chevys10dr
Chevys10dr's Avatar
Thanks Zeroman, that would be awesome, greatly appreciated
Old 09-21-2014, 12:02 PM   #10
Lees68GMC
Lees68GMC's Avatar
Here's my 12 bolt 1975 rear installed in my 68 GMC SWB. These are the stock spring saddle locations and angles resulted and as you can see I'm going to have to install 4 degree angle pinion shims (Speedway) to get the nose of the pinion down. Hope this helps. I did nothing to lower the rear except remove some leafs. Main thing to worry about is oil starving the pinion bearing at such an angle. Something that works good to See straight lines and visualize angles under your dark truck is one of those cheap Stanley laser levels the Wife uses to hang pictures on the wall. That and degree levels should do it.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 09-21-2014, 03:18 PM   #11
Zeroman
Zeroman's Avatar
I set up my diff with the flange on the back of the case vertical "0".
The resulting angle of the bottom of the saddles was 13.5 degrees with the leading edge of the saddles down. This would be for a stock ride height suspension.
As mechanicalman stated though to set the saddles perfectly you would have to have everything in alignment.
Hope this helps.
Old 09-21-2014, 03:28 PM   #12
Chevys10dr
Chevys10dr's Avatar
Perfect, gives me somewhere to start, thanks again.
Old 09-21-2014, 03:34 PM   #13
geezer#99
geezer#99's Avatar
Read this.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
Or this
http://www.drivetrain.com/parts_cata..._problems.html
Old 09-21-2014, 10:29 PM   #14
calvin78612
calvin78612's Avatar
Hope this helps.
Can you show a pic of this ? Not sure I understand what flange your talking about,plus 13.5 sounds like a lot.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
