Old 09-20-2014, 11:04 PM   #1
shultzee13
1999 C1500 Steering Column Problem
I own a 5.7 C1500 Suburban (99) the bottom the steering shaft at the gear box seems tight. But I can move the upper part of the column going into the firewall. Hard to get the sleeve down to see what is the problem. I guess I have to remove the brake booster bracket and master cylinder?
If it is the rag joint is this a major job on my suburban?
Thanks guys.
shultzee13 is offline   Reply With Quote
