Back-up lights
Anyone have ideas on back-up lights for a 55 second series? I can't find anything small yet bright enough. I would like to put them on the panel above the bumper and under the tailgate.
Denny |
Re: Back-up lights
Re: Back-up lights
![]() ![]() Join Date: Nov 2008
Re: Back-up lights
I thought the bed roll lights would be a little cheaper at Mar-K, I was wrong. They must buy them from the same place.
http://www.mar-k.com/Catalog/m/mItem...ID=8245&CID=10
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Re: Back-up lights
In '58, reverse lights were available as a dealer accessory. Part no 987454 covered trucks and Suburbans. The rear lights appeared to be the similar to the white front lights for 55-57 trucks. I posted the instructions in another thread.
http://67-72chevytrucks.com/vboard/s...84&postcount=9 If you choose a light with a 194 bulb, there is a 2 watt plug in replacement available that is used in European cars. I believe the Sylvania number is W2W. Hmmm... These might work well. http://www.ebay.com/itm/BRAND-NEW-Pa...item19d3decbfc Last edited by 1project2many; 09-21-2014 at 01:06 PM. |
#6 | |
Re: Back-up lights
Re: Back-up lights
Thanks to all. I like the bed roll idea, but they aren't cheap. I also like the look of the Alan Horvath idea. I might look for these and other marker or signal lights that can be re-purposed. Thanks again...what a great site!!
Re: Back-up lights
I used a set of driving lights from a custom van.
http://67-72chevytrucks.com/vboard/s...d.php?t=481531 |
Re: Back-up lights
#10 | |
Re: Back-up lights
Here is how he did it Two pack of HF LED flashlights $2.99: http://www.harborfreight.com/led-fla...-12-69065.html Two 1-1/4x 3/4 PVC reducer bushings $1.59 ea.: http://www.menards.com/main/electric...005-c-6424.htm Five pack of carbon film dropping resistors $1.49 (two used): http://www.radioshack.com/product/in...ductId=2062323 Red tail light lens blister pack from Wal-Mart trailer parts rack $3.59 (makes 4 lenses). This picture is taken at an angle, LED's are very directional as opposed to an incandescent bulb. How bright you say? Shine one of these 7LED cluster flashlights in your face and you'll see it first hand: http://www.pbase.com/dennygraham/ima...37355/original Denny Graham Sandwich, IL |
