700r4 TV picture
Does anyone have a picture of the 700r4 TV at the carburetor so I can see how far the plastic sleeve is sticking out mine does not ratchet , if adjust according the procedure it does not ratchet out , the truck is a 1985 c 10 with a 305 with the stock carburetor .
Re: 700r4 TV picture
Hiluxxulih, this is how the TV cable should look like...I'd remove the pan if I was you so that you have no doubt that it's set correct.
http://youtu.be/Fl4GztCFGTc |
#3 | |
There isn't a specific amount it should be sticking out. The cable does stretch over time.
