09-21-2014, 12:36 AM | #1 |
How much to rebuild engine?
So I called a local place about having my completely stock 350 rebuilt. They quoted me $3200. Does that seem fair? I honestly didnt expect it to be anywhere near that much.
1951 Styleline Deluxe 2dr 1957 Belair 4dr 1975 Scottsdale 1979 Silverado 1987 Silverado 1987 Cutlass Supreme (For Sale) |
09-21-2014, 01:22 AM | #2 |
Re: How much to rebuild engine?
You can buy a brand new stock 350 for about $1500 delivered, and that will be more reliable than any rebuild.
As for cost, it depends on what they do. To rebuild it, they have to clean it all up. No gunk left in any passages, oil or water. Then clean the bores, probably run them out .030 over. Clean up the bearing locations. Put it all back together with oversize parts, such as .030 over pistons and rings, oversize bearings, etc. Those are limited production aftermarket parts compared to stock GM on-size parts, so more expensive. Clean all the paint and dirt and oil off, so they can repaint it. Machine the heads, rebuild the valve train, etcetcetc. If you really want a numbers matching engine, then you might do it. But a new crate engine is cheaper, easier, and more reliable.
Rich Weyand 1978 K10 RCSB DD. |
09-21-2014, 01:25 AM | #3 |
Sounds high to me you can get a blue print 383 for 3400.
09-21-2014, 01:43 AM | #4 |
brand new from GM with a 50k warranty for 1700.
http://www.jegs.com/i/Chevrolet+Perf...68758/10002/-1 rebuilding an old sbc isnt worth it unless youre tryin for 10,000rpms or high hp numbers. either way a LS will make that old technology look silly.
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 1963 Scout Retro-mod https://67-72chevytrucks.com/vboard/...d.php?t=854167 |
09-21-2014, 10:11 AM | #5 | |
Yes, rebuilding your engine will cost more, but you will have more options to customize the engine to how you see fit. A good shop will stand behind their products.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
09-21-2014, 10:19 AM | #6 |
Getting Old; Going Broke
Most of you are not factoring in a single dollar for labor. The $3200 has to be a "drop the truck off and we do it all" price. The crate motor prices are just the motor, not all the other little pieces you will need or the $100 worth of break in oil and everything else. Anyone who has done a motor swap knows you end up with another $500 worth of parts you do.
And be careful of that warranty, a lot of times it has to be installed by a certified GM tech who signs off on it, for the warranty to be valid.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
09-21-2014, 02:37 PM | #7 |
Yes the $3200 is if i just take the truck there and drop it off. Thats without them repainting it. Another place in town said my truck is too old for them to work on...
09-21-2014, 05:09 PM | #8 |
I've gotten to the point where I hate to see people put that old stuff back in. Unless they're just doing it for originality's sake and they don't really drive it much. With gas prices you can't even say its cheaper to use the old stuff anymore.
09-21-2014, 05:36 PM | #9 | |
That said, I would rather have the new engine. Also, it's less down time. Mine's a daily driver, so new crate engine is the route I took. Costs me points to use momma's car.
09-21-2014, 10:32 PM | #10 | |
GM warranty is valid no matter who installs it and they will provide the labor to repair or replace it during the warranty.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
09-21-2014, 11:56 PM | #11 |
Best bank for the buck ; http://www.summitracing.com/parts/nal-12530283
Buy a vortec intake and flexplate, be happy. |
09-22-2014, 07:59 AM | #12 | ||
Oh really. Quote:
09-22-2014, 08:22 AM | #13 |
3200.00 is probably not a bad price with them pulling it and putting it back in if you trust their work and want to keep the original engine.
I had mine rebuilt just because I wanted to keep the numbers matching engine that came in it. It cost me 2000.00 with me doing the pulling and dropping it back in. It was a complete rebuild. They bored it .030 over, put in a 268 comp cam, long slot rockers, flat top pistons, new head(one of mine was cracked) new timing gear and chain and they painted the engine for me. Now, if I didn't care about keeping the original engine, it would be a no brainer for me.....Crate engine for sure. This one to be specific Blueprint 383 A buddy of mine put one of these in his truck and it will pin your head back for sure
77 C10 Silverado |
09-22-2014, 08:54 AM | #14 |
Yeah having a shop pull it and put it back 3200 isn't that bad.
09-22-2014, 10:12 AM | #15 |
I can't even imagine paying a shop labor rate to do work like that, I'm able to do all my own work and refuse to pay their greedy shop rate.
I have never seen a shop that is worth $100 an hour. Of course, if you have money to burn or don't have the tools and equipment to do an engine, then go ahead and pay it. But there is also a tremendous amount of satisfaction to be had when you assemble and install an engine yourself and fire it up for the first time and it breathes to life.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
09-22-2014, 10:47 PM | #16 |
I don't want to hijack this thread with an argument and I see your valid info. Although, I've been a service writer/manager for a GM dealership since 1999 and have replaced many engines and transmissions under warranty that were sold OTC and installed by people in their garages and such. Most of the time I have to call and get an authorization prior to replacement and all that info is documented and labor has never been denied because it was not installed by a dealer or authorized facility.
09-22-2014, 10:54 PM | #17 |
09-22-2014, 10:57 PM | #18 | |
09-22-2014, 11:20 PM | #19 | |
Did you read what you copy/pasted? It says over the counter sales warranty starts the date of sale. You just confirmed what he said.
09-22-2014, 11:43 PM | #20 | |
87 V20, Vortec 350, Sm465, Np205, Dana 44, 14bff 4.10's |
09-23-2014, 07:51 AM | #21 |
Yes I read it. Parts only. tyvm
09-23-2014, 08:39 AM | #22 | |
#2 specifically says parts and labor when sold over the counter. Parts only if you fix it yourself, meaning they aren't going to pay you to fix your own vehicle but they will pay a dealer to do it. If you put in the engine and it screws up you take it to the dealer for them to repair.
09-23-2014, 09:08 PM | #23 |
Very well, I stand corrected then.
09-23-2014, 09:35 PM | #24 | |
78K & 79C Jimmys
I could see that with wanting new bolts/valve covers/intakes/carbs/breathers/dizzy/water pump. I 'd ask what worn parts are covered/replaced ,and what could cost to replace extra
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-23-2014, 10:32 PM | #25 |
Over here in the other side of Canada (BC), I rebuilt my 350 last fall. For you folks in the states, things are just plain more expensive here:
0.020" over, hypereutectic pistons, bored with a torque plate. Heads didn't need anything (guides were within spec) - I ported them, modified them for proper spring height, and lapped the valves. Crank didn't need anything, had journals polished. Clevite bearings. Howard's cam, lifters, and valve springs. Indexable double roller timing chain. New oil pump. Internals were balanced. I spent $900 in machining (this shop was pricey), and I'm guessing close to that in parts, if not more. I assembled the engine myself. I was fairly lucky, because the cylinders were the only iffy part (0.003" taper), and I didn't want to gamble just a re-ring. I spent more than I wanted to, but it's a really, really good motor. I have, on the other hand, done engines that I should NOT have, where EVERYTHING was pooched, and costs got out of hand. Assume, for the most part, that it will never, ever be as nice inside as you want it to be. Buying a crate motor, saves the unknown - plus you (might) get a warranty. Your call, but be forwarned that fixing your own ~may~ not be cost effective. A while back I re-ringed a Toyota 4AGE, where the parts alone were more expensive than buying an unmolested JDM engine. Sadly, I REALLY enjoy building engines.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
