Old 09-21-2014, 09:13 AM   #1
Jimal
Jimal's Avatar
Taillight harness routing
I've got the end of the chassis harness, the rear harness on the way, a bed going together, and taillights and a license plate light. How is all of this supposed to be routed under the back of the bed?
Jimal is offline   Reply With Quote
Old 09-21-2014, 09:30 AM   #2
donthekawguy
donthekawguy's Avatar
Re: Taillight harness routing
The wires for the right tail light are longer so they can get over to the right housing and the rest can go down the left side of the frame. If that makes sense. You can attach it anyway you want to the frame. I used zip ties and made sure it was all tucked up in the frame so it wouldn't fall down.
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-21-2014, 10:29 AM   #3
pimpston65
pimpston65's Avatar
my bed has clips on the inside of the tailgate cross sill to tuck the wires away
pimpston65 is offline   Reply With Quote
Old 09-21-2014, 10:30 AM   #4
PGSigns
PGSigns's Avatar
Are all those block welded to the frame? They will need to come off for you stock cross supports to sit where they should. That tank also looks like it may be mounted a little to high to work with your new bed. Set your cross supports where they go on the frame and give it a check.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-21-2014, 10:38 AM   #5
pimpston65
pimpston65's Avatar
there are 2
Old 09-21-2014, 11:43 AM   #6
earl84
No pic, but my 66 fleetside has 5 factory clips across that rear crossmember. Routed from the front all the way down inside the left framerail, and secured with insulated cable clamps. I bought a whole set of them, very inexpensive, at Harbor Freight. Took the time to drill the holes to be sure it stayed in place. PITA, but worth it in the end.
earl84 is offline   Reply With Quote
Old 09-21-2014, 12:45 PM   #7
Jimal
Jimal's Avatar
Jimmy
That's an old picture, but the best one I had of the harness. Those blocks have been cut off already.
