Old 09-21-2014, 09:51 AM   #1
jstrong394
jstrong394's Avatar
Alternator question
Still running down parts for my Ls swap into my 85 c10. Not sure if it matters but it's going carb'd. Is there a way to have a straight plug and play alternator. I have seen that the alternator for the 5.3 doesn't have the correct connection. Can I run the old alternator with the 5.3 and everything hook right up?
jstrong394 is offline   Reply With Quote
Old 09-22-2014, 09:34 AM   #2
Matt Cramer
Re: Alternator question
I just wired the "L" terminal to the alternator warning light wire and left the other three unhooked on my '72 with a stock 4.8 alternator. Worked fine.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 09-22-2014, 01:05 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Fbody 1-wire alternators can be made to fit on the truck brackets, but still have to be modified slightly to work.
What is the issue with the 3-wire setup, do you not want to run it to the ecm?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-22-2014, 03:38 PM   #4
jstrong394
jstrong394's Avatar
From what I have read online I assumed the genIII alternator want work with my c10 wiring harness. I want be using the harness from the 5.3 since I'm going carb'd. I assume that connection on the 5.3 alternator will be different from my c10's connections
Old 09-22-2014, 06:51 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Alternator question
The connection them selves maybe differant phiscally but it can still work by using butt connections I would think.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-22-2014, 07:48 PM   #6
Revorollerr
You can utilize a truck style alternator, one wire hook up with the c10 harness. All you need is the constant 12v to the lug and the key on 12v to the plug (can't remember which terminal) It'll require some resistors inline, 470-480ohm iirc. I'd run the truck alternator, they come in a bigger amp than the fbody alternators. Ls1tech has tons of info in the lsx swaps sub forum.
Revorollerr is offline   Reply With Quote
Old 09-22-2014, 10:07 PM   #7
dayj1
The answer depends on which 5.3 alternator that you're talking about. If we stick to 5.3 (truck) alternators, you really only have 2 choices. The regulator will have either 4 pins or 2 pins. You want the 4 pin style. The pins will be labelled "S", "I/F", "L", and "P". "S" and "P" will remain unconnected. "I/F" will go directly to a switched 12V source and "L" will go to either an idiot light or a 470 ohm resistor. The other side of the bulb/resistor will go to a switched 12V source.
For what it's worth, the 2 pin regulators require a PWM (Pulse Width Modulation) signal from the ECM to operate properly. Pretty much all the Gen IV engines (car or truck) have this style of alternator/regulator. If you already have an alternator with a 2 pin regulator, I posted this how-to on swapping out the regulators on the trifive board a while back. It'll set you back about $20, but that's cheaper than a new alternator:
http://www.trifive.com/forums/showpo...62&postcount=1
dayj1 is offline   Reply With Quote
Old 01-09-2015, 12:25 AM   #8
Gooker928
I'm Confused about what you all are saying.
I've done four or these swaps and all I did was hook my 12v alternator wire from my harness to the LS alternator and hook up the starter wires from my harness to the LS starter. The other connector on the alternator goes to the ECU.
Am I missing something? My 78 Z28 has been running like that for two years.
Gooker928 is offline   Reply With Quote
Old 01-09-2015, 12:35 AM   #9
dayj1
The OP is asking about alternator wiring for a carbureted setup. So he's not using the factory PCM and needed wiring instructions for "stand alone" operation of the alternator.
Old 01-09-2015, 02:21 AM   #10
Gooker928
Oh....
