09-21-2014, 01:34 PM | #1 |
Porportion valve
I have a '87 burb. I replaced the Porportioning Valve, now I can't get brake fluid past the valve. Any suggestions??
09-21-2014, 02:31 PM | #2 |
Re: Porportion valve
Reset the valve. Push and hold in the button on the front. It's under the black rubber cap.
You need to keep it held in until you're done bleeding. |
09-21-2014, 02:35 PM | #3 |
Like a little ball right?? How are you supposed to hold it in while your bleeding it??
09-21-2014, 02:39 PM | #4 |
I pulled the wire connection out and screwed the plastic adapter in that was sent with it
09-21-2014, 03:44 PM | #5 |
09-21-2014, 03:59 PM | #6 |
The button has never popped out to push in.
09-21-2014, 04:04 PM | #7 |
How do you know that?
Do you have any brakes at all? What else has been done besides changing the prop valve. |
09-21-2014, 04:40 PM | #8 | |
The newer valves don't need to be reset like the older ones.
09-21-2014, 04:46 PM | #9 |
Buy or borrow a vacuum bleeder and force fluid in from the bleeder, it should free up.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
09-21-2014, 06:50 PM | #10 | |
She needs it for work tomorrow, I pulled it back off and put the new one back on. It was just leaking. I'll tackle it again when I get a chance. I'm trying a vacuum bleeder and got nothing. |
