Pic needed of gas tank skid plate mount
Greetings
Finally getting around to installing the skid plates I scored for my 72. Can anyone post up pics of how the tank skid plate mounts to the frame. Thanks in advance Tbruz |
Active Member
![]() Join Date: Jun 2013
Re: Pic needed of gas tank skid plate mount
Tbruz,
I'm surprised no one's answered your question. I recently R&R'd my tank to clean it. My skid plate is still out. I'll try and get some pics for you this weekend. They pretty much just use long, approx. 5/16" bolts that have a hook on the top end that grabs holes in the frame and the other end is threaded, which goes through wholes in the edges of the skid plate. I'll verify this weekend and get back to you. Morey
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. ![]() Members Met: Aldtime, DeadheadNM |
Thanks Moreyel,
Appreciate any pics of the hardware and mounting orientation as well Tbruz |
All you need to do is drill 4 holes in the frame to mount it up. Some bolts, flat and lock washers and your good to go! That's if it is a stock skid plate. Mine came off a 1972 2wd suburban. Just bolted mine back on, and posted some pic's on my thread on the projects site a while back. Not the best pic's, but you can see it just bolts to the frame.
Active Member
Tbruz, swyfor5 is right. I dont know what made me think it uses the long bolts with hooks. I took mine out last winter to clean & fix the tank. I left the bolts (3/8 x 1/12-2) in the frame that you can see. If I remember right, orientation is the angled end faces forward. There's also another plate that protects the fuel inlet & vent lines.
Morey Man, I've been trying to upload pictures and cant get it done. I'll try again tonight. If you hold the skid plate up against the frame over the tank, you'll see the bolt holes in the frame flange that hold it up.
PM sent to Moreyel
Let me know if you still need pictures. I should be installing mine in a few weeks and can post some pictures if you need me too.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
Can always use/look at more pics!!
Appreciate it. Tbruz |
![]() Join Date: Jan 2014
I'll post some pics of mine tomorrow. See if you guys can tell me if it's how it's suppose to be mounted.
#10 | |
Thanks,
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
Here ya go.
72 CST 4x4 Blazer, 1 ton 70 SS Chevelle, L78, 396 Everytime someone calls your Blazer a Bronco, God kills a kitten. |
Wow, that's clean under there!
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
#13 |
GMCDAC
Hey guys, I hope you all don't consider this a hijack. Still on the subject of fuel tank skid plates!
Warbucket's super-clean setup made me want to ask if the skid plate is aftermarket or GM? It dawned on me looking at his pics that the abused one I recently got may have been the same as that nice one. It's rough, and I thought it was probably a home-made deal. Came off of a '72 Blazer. Thanks in advance---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
#14 |
From what I've learned through a few of the members here is that they came stock. I picked one up a few weeks ago and had it powder coated. Came out real nice.
#15 |
Active Member
Dark Olive, Here's some more pics showing bolt hole orientation. You can see where my bolts are coming through the frame flange in relation to the parts near them.
#16 |
Active Member
I'm not sure why the other pics didnt upload so I'm trying it again.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. ![]() Members Met: Aldtime, DeadheadNM Last edited by Moreyel; 10-14-2014 at 01:34 PM. Reason: Trouble getting pictures downloaded. |
#17 |
I believe the one you got it a stock one. It looks identical to most of the ones I've seen.
#18 |
Moreyel - Thank you. I'm book marketing this page because its going to be a while before I get to installing this. Those pics really help/
Thanks Mike
