Old 09-21-2014, 04:39 PM   #1
crazyjim
crazyjim's Avatar
Speakers
What is some of the ways you can mount speakers in a 1967-72 chevy with out cuting the doors?
crazyjim is offline   Reply With Quote
Old 09-21-2014, 05:10 PM   #2
chiefcfd
chiefcfd's Avatar
Re: Speakers
You can mount them under the seat or use the kick panel with speakers. If you relocate the gas tank there's lots of possibilities.
http://sokyclassics.com/product.php?skcid=1000275
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 09-21-2014, 08:53 PM   #3
n33k0
Re: Speakers
I have two 6x9 speakers behind the bench seat, gas tank relocated out of the cab. With them mounted behind the seat they can sound muffled, so I have to boost the high frequencies on the radio to get them to sound clear. It's not a big issue for me, but if your radio doesn't allow much frequency adjustment, that's something to consider.
n33k0 is offline   Reply With Quote
Old 09-21-2014, 09:11 PM   #4
AirSpeed
AirSpeed's Avatar
Re: Speakers
I have a pair of 10"s under the seat mounted in a box's that' are just short enough to fit. When I bought the truck it had holes in the doors so I mounted a pair of 6" midrange drivers and some 1" tweets right above the AC vents.
AirSpeed is offline   Reply With Quote
Old 09-21-2014, 09:36 PM   #5
leftybass209
leftybass209's Avatar
Re: Speakers
There's also kick panels made to accept speakers.
leftybass209 is offline   Reply With Quote
Old 09-21-2014, 11:01 PM   #6
Lattimer
Lattimer's Avatar
Re: Speakers
I did the highliner headliner for my speakers and radio. Pics of it installed at the links below:
http://67-72chevytrucks.com/vboard/s...&postcount=193
http://67-72chevytrucks.com/vboard/s...6&postcount=58
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 09-22-2014, 09:35 AM   #7
4oldcars
4oldcars's Avatar
Re: Speakers
Don't these speakers have to be a certain "ohm" to operate on a factory radio? Just askin.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 09-22-2014, 11:32 AM   #8
leftybass209
Re: Speakers
Yes, typically you can always go over the ohm rating ie: 16 OHM speaker with 4 OHM output, but not the other way around. I think it's a funny number, 10 or 11 OHMS for the original speaker.
Old 09-22-2014, 09:24 PM   #9
Mike C
Mike C's Avatar
Re: Speakers
My favorite way is putting a set of components in the door PANELS and not the door. I have 4" co-ax in the Jimmy in homemade door panels and I mounted 4" components in my old Sierra Grande in the OEM metal door panels.
A set of reproduction or homemade door panels is my vote, then if you change your mind you swap out the panels and the hole for speaker clearance disappears again behind the panel. Put the woofer down low in the door handle and not in the way of the window crank and the tweeter as high up towards the front as possible once again out of the way of the window crank. A 10" subwoofer under the seat rounds this setup out.
On my '69 short step I'm planning on 5 1/4" co-ax's in the door panel and 4" round speakers mounted under the OEM grill in the dash. A 5 channel amp will drive each of those separately along with a 10" sub under the seat.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-22-2014, 09:31 PM   #10
michael bustamante
michael bustamante's Avatar
Re: Speakers
Anybody got a lic of a 10" sub under the seat? Box dimensions too?
1967custom
michael bustamante is offline   Reply With Quote
Old 09-22-2014, 09:42 PM   #11
Grumpy old man
Grumpy old man's Avatar
Re: Speakers
Do you mean a picture ? Some of us are really old school and have NO IDEA what your talking about ?
Grumpy old man is offline   Reply With Quote
Old 09-22-2014, 10:24 PM   #12
RaceAGMC
RaceAGMC's Avatar
Re: Speakers
I'd like to see the door panels with the speakers in them.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 09-23-2014, 02:17 AM   #13
leftybass209
Re: Speakers
I don't have a pic but there are subs made to slide under the seats. http://www.customclassictrucks.com/t...s/dynamat.html
this link may help.
Old 09-23-2014, 09:58 AM   #14
csfields
csfields's Avatar
Re: Speakers
Here is my all Kenwood system with a Classic Autosound head unit w/ aux port. 2 four inch speakers in the dash, 2 six and half inch speakers in kickpanels, 2 six and half inch speaker in the rear along with 1 ten inch sub all running off one 900 amp.
As stated earlier, if you can get the tank out of the cab the possibilities open up quite a bit.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 09-23-2014, 10:20 AM   #15
michael bustamante
Re: Speakers
Haha yeah a pic. I got fat fingers
1967custom
Old 09-23-2014, 10:23 AM   #16
michael bustamante
Re: Speakers
This looks real nice! Did you buy the sub box as is or was it made?
1967custom
Old 09-23-2014, 11:26 AM   #17
csfields
csfields's Avatar
Re: Speakers
It's a premade Kenwood Exceleron sub box. I like it alot.
Thanks,
Casey
Old 09-23-2014, 05:40 PM   #18
michael bustamante
Re: Speakers
Cool thank you. Time to lookon amazon!
1967custom
Old 09-23-2014, 06:42 PM   #19
slowcpe
slowcpe's Avatar
Re: Speakers
I know they make shallow subs but not sure if they would fit under the seat with a box or not. There's not a ton of room under there. Plus doubt they would sound real good. I know in the home environment, I haven't heard a shallow InWall sub sound decent.
If you're not going for true audiophile sound, I'd say a nice pair of 4"s in the stock dash location and 6x9s in the rear cab corners would sound just fine.
My current setup is a pair of RF Punch 4"s in the dash, Punch 6x9s in the doors (holes where already there) and a RF 4-channel amp. Just running my phone directly to the amp now. It doesn't sound too bad. If I had a nice head unit/preamp I think it would sound real good. Definitely for 80% of the truck guys out there.
I'm considering at this point to eventually fill the doors/get new ones and add speakers in the kick panel. Then I may look into 2-3 8"s behind the seat.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 09-23-2014, 07:15 PM   #20
JJanzen
JJanzen's Avatar
Re: Speakers
Here are a couple of ideas that I used. The first image is a drawing of an mdf box I made and painted black to be located under the seat. It holds a 10" woofer, an amp and a reciever unit. The touch screen is mounted in front of the original in dash am radio. The second picture is of some custom kick panels I made from 1/4" mdf, 1/2" mdf ring, an old t-shirt, fiberglas and some two way stretchable black trunk liner fabric. The last part of my stereo is a custom set of stereo speakers in the original dash hole. I have attached a two pages showing the drawing/plans for that item. Please let me know if you have questions. If you want full size plans, send me an email and I'll forward PDF's. They were too big to upload. JJ@3DxDenver.com
Blue72
Red72
JJanzen is offline   Reply With Quote
