![]() ![]() Join Date: Apr 2012
Wtb 1967 chevy truck clutch fan
Looking for a correct 1967 Chevy truck clutch fan, Thanks !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
![]() Join Date: Aug 2013
Re: Wtb 1967 chevy truck clutch fan
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
Could you do me a favor and measure the diameter of the hub that bolts to the water pump
"Trucks with Class"
![]() Join Date: Jul 2000
[B]The hubs and blades are the same size on all SB 67-72 clutch fans, but the bolt pattern is smaller on the 67-8. That means the bolt pattern on the WP pulleys must match the fan. jmader's looks correct if it will match your pulleys.
Sure I'll get you a measurement of both the hub and the bolt pattern tomorrow.
Yes and no, I have an identical fan blade In every detail, but, the nos original gm clutch has a larger hub dia that I asked for the diameter on. It will not fit through the hole in the blade. I need the larger hole and bolt patern blade for the clutch to bolt to. Passenger car blades are smaller but look identical , trucks are larger in the center opening, that's why I asked.
Here are a couple pictures. It looks like the hub is just over 2 1/2 inches wide and the bolts are about 1 3/4 inches apart. Hope this helps.
That's the one ! PM next
Need one more as pictured above. Thanks
