![]() Join Date: May 2010
Reputable body shops St.Charles MO
Sadly, after three inner rockers and two outer rockers, I've given up. I'm just not a body man at all. Having said that, is there anyone out there within the St.Charles MO that knows of a good, reputable body shop? Or would anyone know what they're doing wanna stop by and assist? Will pay!!
Ive searched through this forum time and time again and most make it look easy, and there is definitely a skill involved in doing this. I just do not have it ;( So if anyone knows, please reply. Comments most welcome! |
Re: Reputable body shops St.Charles MO
Labors 70 an hour at Old dog street rods in Maryland heights, not that far away and my dads the one that'd be doin it. I trust him with my truck and it'll be done right.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
Any pics?
![]() Join Date: Apr 2010
Gittemier auto body in St.Charles ask for Tim. 636 928 0226
I can get some. Most likely tomorrow. I need an inner rocker, a pillar, b pillar, cab corner and outer rocker. I have all the parts. Just cant get things lined up and the door to fit..
What's the price for labor? |
If you want to to come to the open house we're having on Oct 4th you can come have fun and see some awesome cars, see what we do there. 72 n under parks on the lot and newer parks across the street.
![]() Join Date: Dec 2013
Always talk to previous customers and more than 1-2 ask for references and look at past work that being said I used to print this on the back of our business cards ...
1) QUALITY WORK 2) FAST TURN AROUND 3) LOW PRICE PICK TWO BECAUSE YOU CAN'T HAVE ALL THREE ! You can have quality work and a low price BUT it won't be FAST ! (your truck will be used as fill in work and may sit for untold months ) You can have quality work and fast turn around BUT it won't be CHEAP ! You can have fast turnaround and low price BUT it won't be QUALITY ! ![]() |
As a painters son, that's the damn truth. Pardon the language
#9 | |
#10 | |
In the few months I've been on this forum and the couple years I've stalked it before joining I've never seen a truer post from you Grumpy.
#13 | |
What I would most like to do is get with a buddy from here, someone who knew what they were doing and was serious about a good job, and allow me to put my truck into their garage and he and I work on it together. It needs a frame off for sure although the frame seems solid. Cab corners and rockers need to be cut out and replaced but I've managed to find all the fenders I'll need (original too) so there's that. I'd pay the fellow as well as take care of any expenses. I'm hoping I can learn how to do some of this stuff as he and I go through it. I'm not at that point though. Barring that, I'd hire a guy straight out to do a frame off but I realize that isn't cheap (20K or so?). |
#14 |
Stock frame off or custom build?
#15 |
Stock. I'd just like the truck to go back as close to it was when my dad had it.
Only thing I'd do differently is put in a radio, cell phone charger, ignition kill switch, and a couple of cameras and screens to make parking easier. Oh and move the gas tank to the rear. Mainly I'd like to get rid of any rust. |
#16 |
Just a quick pic. But as you can see the inner is just tacked in. I have the outer rocker to put on, the A pillar, the b pillar is tacked in, and the cab corner
This process needs to almost be completed on the other side. Although the rust isn't quite as extensive on the other side. Having said that, I've already put in the cab floor braces underneath. That was a job in itself. But basically I've had this in several times, and I'm still hitting the door. I bought the doors from a member on the forum, and they are GM doors. All the sheet metal are aftermarket. Again I completely understand that massaging and tweaking are apart of the process, I'm just not that skilled. And I've wasted countless hours on this. As a matter of fact between my rebuilding of the suspension and trying to stay away from this rocker job, I started cutting everything a year ago this Oct! |
#17 |
1st always weld a brace the opening before cutting anything out/off ,make sure the cab has been squared and level on whatever stands hold it off the ground and that they (the stands) are not holding the cab up by the floor pan only .4 jack stands and 2-2x6 boards can be used for lack of steel supports , I use a specific built wheeled stand for this stage with adjustable struts to maintain square .I need more pictures to see exactly what your having problems with but I would refrain from cutting so much out at one time and your floor braces just might be welded in the wrong position/height and that may be whats throwing you off and making the door hit ? measure 3 times cut and weld once !
