09-21-2014, 09:01 PM | #1 |
Tranny and rear end combo question
Hey guys, first post here. I have a 1966 Chevy C10 pickup, and in it is a 250 straight 6 paired to a column shifted muncie 318. I absolutely love this truck and wouldn't consider trading or selling it. The truck drives wonderfully for the entire drivetrain being all original, however, this truck is terrible on the highway due to it's gearing. It currently has what I believe to be a 4.11 rear end in it, and at about 62mph im pushing 3k rpm. Recently I have been researching swapping either the muncie 318 for a 319 o/d or the 4.11 rear end for a 3.08. My question being, what do you guys think about either of these swaps, and would the 3.08 gears be ok with the muncie 318 and the 250 straight 6? Thanks, any help is greatly appreciated.
09-22-2014, 01:28 AM | #2 |
60-66 Nut
Re: Tranny and rear end combo question
The size of your rear tires play a part in this also. If you are running say a 235/75R15 then I wouldn't go any higher than a 3.42 gear with an OD trans. You do not want the lowest rpm's possible. Instead you want the engine to operate in it's peak efficiency rpm range.
09-22-2014, 07:14 AM | #3 |
My rear tires are 225-75/15, I think that's like a 28" diameter. But I think 3.42 gears with an o/d would definitely be enough, however I was considering swapping the rear end to 3.08 gears or swapping the transmission for the o/d tranny, not both.
09-22-2014, 09:38 AM | #4 |
To decide if your truck will be happy with a 3.08 gear or o/d just drive at 45 to 50 mph on the highway and see how it accelerates from that speed.
If it just sorta bogs down and refuses to go faster then you'll know a swap is a waste of time. |
09-22-2014, 11:50 AM | #5 |
I have a 63 with the same combo. The PO added 3.08's. what a dog. the truck runs out of steam going up hills. Rowing the boat the whole way. 2nd/3rd over again.
I was told by Langdons to just put the 3.73's back in and go to a 30% over drive. Adding power on helps on the top end. Got to love that shop. Actually giving good advice and not trying to sell you something first. On the plus side I am getting 18.4 mpg. |
09-22-2014, 12:19 PM | #6 |
The HP for a 283 is listed as 184hp. So the 250 would be less. So you have to stay in your power band. Here is a Gearing chart. I run a 28" tire with 3.73 gear and a .67 OD gear or 33%. Around 2000rpm@75mph
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
09-27-2014, 12:34 PM | #7 |
Greetings from Oakland CA. I've got a '63 with a 3 sp (no OD) and a 411 dual posi on the rear. Tires: 275/60R15. You know the problem, I'm hittin high revs at 60mp and the gas just disappears. I'm trying to fiqure out via this forum of smart wrenchs, how to re-gear my ride for higher top-end and mpgs. Do I need to change the tranny and obviously regear the rear too? I'm a bit lost on this. Your thoughts and knowledge of the subject would be helpful- thanks mtg!
09-27-2014, 09:49 PM | #8 |
my old truck wasn't the fastest off the line with the 3:08 and the 250 but it still would pull a load. it also really loved the highway and where i live thats all there is. it did good as far as mpg at 70 was running @2000 rpm
Between saying and doing many a pair of shoes are worn out |
09-27-2014, 11:38 PM | #9 |
342 was common in the 5 lug squarebody wasn't it? Should be a cheap n' easy one to score. You could roll it without o.d. see how it goes and still go with Captain's idea of adding an overdrive later if you want. Plus then you can go with 5 lug disc up front later too and the rear would be matched.
09-28-2014, 12:13 AM | #10 | |
60-66 Nut
Welcome to the forum
You didn't say what engine your truck has, which does play a part in the recommendation. Just guessing I would say you would need to change the differential gears to either 3.42 or 3.73's and also go with an OD trans, either manual or auto. You could alternately keep the 4:10's and go with an OD trans and a taller rear tire. Quote:
09-28-2014, 10:12 AM | #11 |
My longbed has a 308 rear with a stock 283. It still has a column shift and it drives great on 225/75-15 tires. But any less motor and it might need numerically higher gears. Especially if I wanted to pull a boat or something. I believe I would struggle a bit to pull anything larger that a personal watercraft and camping gear as I am, but have never tried it.
09-28-2014, 01:25 PM | #12 |
Thanks Captainfab.
Sorry, the engine is a 351 so it's got plenty of get-up. Appreciate your thoughts. If you have any add. suggestions plz send along. I'm just trying to sort this out so all info is helpful. I stumbled on the forum and it's very helpful and plenty of great trucks. |
09-29-2014, 12:05 AM | #13 |
60-66 Nut
OK, so I assume that your '63 is a GMC with the 351 V6? If so the your engine has enough low end torque to pull a taller gear. The problem with changing the gears to anything higher than 3.73's is that you will have to also change the carrier. Which means you will loose your posi unless you buy a 3 series posi unit. That adds about $400 to the cost. The next issue is that with the GMC V6 you are limited as to which OD trans you can use. You will not be able to use the NV3500 or NV4500 trans. You will have to go with either a T5 or the MY6/NP440 trans.
I would say you first need to set a budget and see which changes you can get done within your budget.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-29-2014 at 12:17 AM. |
09-29-2014, 11:40 AM | #14 |
Yer best bet....go to a 30 inch tire...convert to 3:73:1 and throw in a 5 speed. Even if you stay at 4:11 a 5 speed will help. That little 250 will pull just fine even with something as tall as 3:42:1. The 250 had 134 hp and 215 pound feet of torque...that was advertised...the HP and torque specs changed...but I like to believe the lowest specs because that's what it feels like the engine produces IMOP...My 292 was advertised as 153 HP and 270 torque..Net specs...Gross were 180 and 280 torque. If yer wanting to stay completely stock....taller tires and a little taller rear gearing won't hurt a bit. It'll be a tad slower on acceleration, but that'll just give you an excuse to throw a turbo on.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-02-2014, 10:28 PM | #15 |
Ho boy! Well the engine is a 351, V8. But your comments help me have a conversation with the mechanic. If he's got have the car-brain you have, we might be able to sort it out. Budget? Yep, got my own money-pit just like everyone else but hope I can find, with all the suggestions/recommendations, a way to change the tranny over with out going into deep hock :| Adding your comments to the others hoping to have a talk with a mechanic soon. We'll let you know, run it by you- thanks ELD
10-02-2014, 10:53 PM | #16 |
the t5 trans is not one that you can abuse or you will be replacing it and with the torque from that 351 and a big foot won't last. if you drive it civilly you should be ok
ron |
10-03-2014, 12:21 AM | #17 |
60-66 Nut
A 351 V8 is a Ford engine........
10-03-2014, 01:12 AM | #18 |
10-04-2014, 10:07 AM | #19 |
Hey CaptianFab,
Yes, the engine is a small block crate, V8. Still gathering tranny comments so thanks again for your thoughts. ELD |
10-04-2014, 10:09 AM | #20 |
Thanks for the thought. No, just a regular driver, not in any hurry to get there so just want to rework the tranny so that I can increase top-end, gas mileage but maintain a little get-up and go when I need it. So, the comments have been real helpful. ELD
10-04-2014, 10:17 AM | #21 |
Thanks TJ. Swapping out the 3-sp auto with a 5-sp could work. Seems like adding an OD to a 3-sp is challenging and then I need to regear the rear. But the comments to give plenty to think about and I'm still sorting it out. ELD
10-04-2014, 10:35 AM | #22 |
If you go by the chart I posted the 3:73 and overdrive is in the sweet spot with a 28" tire. So no mater what you do your truck is still a brick and not a Prius. Find a tire size, choose a transmission, then dig into the rear. You will find that sweet spot.
10-05-2014, 08:55 PM | #23 |
