Old 09-22-2014, 12:55 AM   #1
akart
K20 1982 6.2 Ratio
Yes, I know I should open it up and look but I would like a guess or two on the ratio of the rear end on a 1982 K20 6.2 diesel 14 bolt GM rear with the 10 bolt GM front which I have bolted up to a 350 manual 4 speed and a 205,1974 frame '86 body, 350 is a crate. Thank you
akart is offline   Reply With Quote
Old 09-22-2014, 06:11 AM   #2
D13
D13's Avatar
Re: K20 1982 6.2 Ratio
Since the 3.24 version of the 14 sf bolt is rare, I would suspect 3.43. But if you've done all that work, then 3 minutes with a floor jack should be easy for you, and would tell you the info. Or pull the cover, could probably use a fluid change anyways.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 09-22-2014, 07:47 AM   #3
86c20
86c20's Avatar
6.2 factory truck i would guess where its a 3/4 and 4wd 373 or 4.10 i dont see lower for a 4 wheel truck. not factory
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
