09-22-2014, 12:32 PM | #1 |
function of brake switch at proportioal valve ?
Hy all
in the past i had installed a separate brakes switch ....so at the moment i am redoing the brake pedal / brake booster setup. This time i would like to use the brake switch which is mounted directly at the proportional valve... As u can see on the pic ...the brake switch does have a small nippel on the bottom side.. On the other side it has 2 pins for a plug (or wire) So if i press the nippel ..i thought i will get a connection (or disconnection) of the 2 pins on the top of the switch... But "no"... the 2 pins are always connected....i just get a connection of the pins and the nippel itself... So i am really confused right now....how can i handle the brake light with this kind of switch Thanks for ur help |
09-22-2014, 12:38 PM | #2 |
Re: function of brake switch at proportioal valve ?
The combo/prop valve has a "shuttle" in the center of the housing, which closes off the defective branch (front or rear) if you lose pressure.
The electrical portion is what illuminates the warning light in the dash, notifying the driver there is a problem. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-22-2014 at 12:50 PM. |
09-22-2014, 12:44 PM | #3 |
ahhh ok ...sorry for my half knowledge :-)
i thought i can use that switch to control my rear brake lights... than i will use a separate switch again Thanks Achim |
09-22-2014, 04:53 PM | #4 |
I have never hooked mine up, I like surprises....
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
