![]() Join Date: Jul 2009
Glove box won't latch
Am i missing something here. Seems that my glovebox is mounted wrong or something. The latch is not high enough to catch.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
Re: Glove box won't latch
another pic
another
![]() Join Date: Dec 2013
add a spacer to the hinge and be done with it ! it worked when you took it off did it not ? OMG.
the cardboard liner gets sandwiched under the door. that should raise it up enough..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
The Older Generation
Did you add the locking latch or has it always been on there? How about a picture of the back of the lock. LockDoc
Old member
The part on the dash can be adjusted also a little. Take the screws loose and let it drop down as far as it can. The cardboard insert should be between the glove box door and dash as mentioned.
You picture is missing the side bar also that stops the door when you open it. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I'll order the glove box liner and get a pic of the lock. I had three doors and the painter lost the one that went to this cab so this one is now of my spares
Do I get the glove box with or with out ac. I won't have factory ac but will have vintage air.
Vintage air uses its own plastic formed glove box.
