Old 09-22-2014, 10:27 PM   #1
zicc1835
zicc1835's Avatar
speedo cable
i converted a IL6 with 3ot to sbc and a 4speed m-20 and the (hook up is on oppisite side of trans)speedometer cable is short any suggestions is there a part # from a different year or model like a chevelle or el comino sure someone has had this issue
thanks
jz
zicc1835 is offline   Reply With Quote
Old 09-22-2014, 10:57 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: speedo cable
If it was me, I would get a measurement of you existing cable plus the additional length you need and have a speedometer shop make you a new one. They should be able to set you up for around $30.00 - $50.00.
Other wise, you may find a application for a car that will work but you may have to play trial and error to get it right.
Just my thoughts,
Take care,
tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 09-22-2014, 11:01 PM   #3
zicc1835
zicc1835's Avatar
Re: speedo cable
than you i will see what i can find out let you know how i make out
thanks
jz
Old 09-22-2014, 11:22 PM   #4
kitsbeach
kitsbeach's Avatar
Re: speedo cable
thanks
jz
I just took the shorter tranny out of my 67 and had to buy a longer cable from brothers. Mine was on the same side though before and after.
Here is the one I bought. It says it doesn't work with 4WD.
http://www.brotherstrucks.com/prodin...number=PLCBL01
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 09-22-2014, 11:51 PM   #5
zicc1835
zicc1835's Avatar
Re: speedo cable
thanks for that info
