Old 08-11-2003, 11:40 PM   #1
loweredd
www.loweredd.com
loweredd's Avatar
Unhappy axle leaf spring perches....LOL HELP!!
LOL, I hope you know what I mean......the perch that is welded on the axle that mounts on the leaf springs. I need to know where to find new ones if anyone knows where.
P.S.....it's for my 84.
loweredd is offline   Reply With Quote
Old 08-12-2003, 10:43 AM   #2
SCOTI
SCOTI's Avatar
www.detroitspeed.com has a bolt in style leaf spring pad that you can move exactly where you need it, set the pinion angle, then weld it into place. Try the link & look @ rear suspension parts (their stuff is mainly for cars but as long as your axle tubing dia is 3" they will work).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-15-2003, 11:30 PM   #3
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Summit sells these. I bought a set at a local 4 wheel supply house, For some reason they say there for a DODGE!!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 08-15-2003, 11:42 PM   #4
crazy longhorn
Fabricate till you "puke"
http://store.summitracing.com/partde...rt=MOR%2D85090 The mopar brackets are a little cheaper than the Moroso http://store.summitracing.com/partde...=DCC%2D4120074 these are the ones i used on the 12 bolt swap into my longhorn.......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-16-2003, 04:29 AM   #5
loweredd
www.loweredd.com
loweredd's Avatar
dang, thanks guys. I tried posting earlier that I never got an email when Scoti posted, but my internet was being a pain. I actually found some from rockequipment.com....some 4x4 place in CA.
Those you linked to are actually cheaper longhorn.......I never thought to check my parts sales competition. LOL.
