Old 09-23-2014, 12:33 AM   #1
87Skier
87Skier's Avatar
96 Suburban AC not working
So I've had my Suburban for a year now and I figure I should fix my AC even though summer is almost over.
Some background: First, I don't work on AC systems much and don't have a lot of prior experience with them. Second, I don't know when the last time it worked was. Third, the suburban has rear AC (not sure if that changes anything).
When I got it I thought I would check out an electrical issue, so I turned on the AC and jumped the pressure switch on the passenger side of the suburban, the compressor kicked on and clutch engaged properly. I immediately disconnected it to prevent damaging the compressor. Next, I thought it might just be low on R-134a so I used my left over recharge kit on the suburban. When I hooked it up and starting charging my system, the compressor kicks on. As soon as I released the trigger, the compressor would turn off.
I'm not really sure where to go from here. Is my system leaking? Do I have a bad switch?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
