Old 09-23-2014, 10:56 AM   #1
Gregski
Post Whore
Gregski's Avatar
What Oil Weight Should I Use In California
I know I know right, wars have been started over oil questions. And yes I did do an Advanced Search on Oil and all I saw were Oil Pan and Oil Pressure posts.
So specifically in California where temps do reach above 100 in the summer and maybe one or two days of freezing each winter, what oil weight not necessarily brand should I use?
Thank you guys
FYI: I like to use cheap AutoZone oil in my cars but I change the oil and oil filter every 5,000 miles religously and have not had any issues.
1974 GMC 1500
1/2 Ton Short Bed
2WD
Manual
350 four barrel
All Stock
Gregski is offline   Reply With Quote
Old 09-23-2014, 12:21 PM   #2
79Betty
79Betty's Avatar
Re: What Oil Weight Should I Use In California
In southers indiana it gets 95+ each year and -0 too, but i use 10-W30 without issues in my 74. My ranger gets 5-W20 but only because i've had it since new.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-23-2014, 12:25 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
I run 10w40 in my 83 Silverado with the 305 year round, Pennz High Mileage oil is my choice. Have 219K original miles on her
Malo83 is offline   Reply With Quote
Old 09-23-2014, 07:47 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I have been using 10W30 Trop Artic oil in my engines, ever since I used to work for a small county highway department. Those rock hauling trucks had over 300,000 miles on them and the insides of them were as clean as if they were just assembled. We changed oil regularly on a 3000 mile basis and worked those engines hard. Kansas sees temps from 100+ to zero degrees and we used these trucks for hauling rock and pushing snow. Of course, being in California, you could only use it until you crossed the border into another state, then you would have to use something else. LOL
Frank
piecesparts is offline   Reply With Quote
Old 09-23-2014, 07:56 PM   #5
Dead Parrot
The oil cap on my GM 350 crate motor says 10W-30. I think the 75 owners manual had 10W-30 for most times and 10W-40 for high temp climates. Have used 10W-30 synthetic blend since installing that motor. When I started, there was only a couple dollar difference between that and the cheap stuff. Change it every time the thousands digit rolls to a 0 or 5.
Dead Parrot is offline   Reply With Quote
Old 09-23-2014, 08:04 PM   #6
dfrank
dfrank's Avatar
Any good quailty 10w-30 or 10w-40. I prefer a 10w-40. Remember though if you have a flat tappet cam you need a zddp additive. I also prefer a good dino oil like Penzzoil as I have noticed that synthetic oil's tend to burn a little more oil than standard dino oil as it is slicker than dino oil and can slip past the piston rings easier.
dfrank is offline   Reply With Quote
Old 09-23-2014, 08:05 PM   #7
rich weyand
rich weyand's Avatar
I use Mobil1 10W30 full synthetic with one bottle of ZDDPPlus per oil change.
Note that if your engine has oil leaks, do not use full synthetic. It will run out lots faster than dyno oil. But if the engine is tight, synthetic oil IMO is better. Slipprier.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
