Old 09-23-2014, 09:25 PM   #1
1962 Panel
1962 Panel's Avatar
Panel truck patch panels
Does anyone know if anyone makes patch panels that are specific to panel trucks or suburbans, like for the bottoms of the rear barn doors or the lower rear quarter panels? I haven't been able to find any on the interwebs.
1962 4x4 Panel Delivery. 327 / 300 HP, Orig. SM420, Rockwell T221, 10 Bolt Rear/ Dana 44 Front. Project.
1977 Ford LTD, 302/C4, 18,000 mile survivor, daily driver.
That's right, a Ford. I'm bi-partisan.
1962 Panel is offline   Reply With Quote
Old 09-23-2014, 10:03 PM   #2
chevyman1968ss
Re: Panel truck patch panels
I have a 64 panel in the works with some rear quarter damage on both sides and to my knowledge no one makes patches for them.I am having to cut out the damage (crushed ) straighten & weld back in place .Same on rear doors. Hope this helps! Good luck.
chevyman1968ss is offline   Reply With Quote
Old 09-23-2014, 11:01 PM   #3
1962 Panel
1962 Panel's Avatar
Thanks for the reply chevyman, I kind of had a feeling that no one makes replacement panels specific to these trucks (some day maybe...). Unfortunately the damage I have is all rust related, nothing to reshape there . This might be a job for some metal fabrication and a tub of bondo when the time comes to do cosmetic work. Good luck on your 64 panel, these truly are very cool trucks.
Old 09-24-2014, 11:01 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yeah, no one really makes specific items for panels/suburbans. Some repair panels for trucks will work but things like the rear doors, tail light areas, etc. are not made. If yours are beyond repair, you'll likely need to find some used replacements in better shape.
I would suggest you become a supporting member and then you can post a Want to Buy ad and see if fellow owners have some spares pieces you could buy.
Good luck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
