Distributor preferences
ok so I'm pretty sure i need to get a new distributor. I've been looking at both MSD and Mallory Dist. specifically the MSD pro billet Dist kit with Digital 6al ignition control and the Mallory Max fire Dist. what are your thoughts on these or others out there?
1972 Chevrolet swb fleet side. - SOLD 2018 Toyota Tacoma but hunting for another C10 Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303 Instagram: https://www.instagram.com/72c10shortbox/?hl=en |
Re: Distributor preferences
What motor do you have, as in, is it a 900hp alky motor? If no, then the digital box is really just a cool lookin part..
The stock GM HEI is good to 7k, and with blueprinting it will spin higher than your motor can. The MSD units are nice looking, so it really is up to you, 100 bucks or 800 bucks.
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
#3 | |
Blueprinting a stock style HEI is a little time consuming and getting the advance weight/spring combination is tricky, or you can spend the money and get it curved at a speed shot, but still unless you run it on a dyno you don't know if the curve is right. With the MSD 8365 each set-up it comes with has it's degree and RPM specs so you will likely get it right the first, second, and worst case scenario the third time you take the cap off and switch out bushings or springs. So you will save on headaches with the tune-ability. BTW, I did my stock HEI the hard way (was worth it in performance and fuel economy), and it works great, but if I had it to do over I'd get the MSD pro billet. Simply put, voltage above what a stock HEI puts out (up to 400+HP) will not boost your performance enough to notice, however, a properly tuned distributor will make a huge difference in a performance engine with a factory style distributor curve, plus the pro billet has a module and coil setup that produces 100 millijoules of energy across the plug gaps. Only thing, I don't think the MSD comes with an adjustable vacuum pod (can't find anything that says is does or doesn't), and I'm not sure if the aftermarket ones for the HEI's fit the MSD HEI. I suppose you could contact MSD on that if you are concerned with cruise fuel economy tweaking. If it turns out the stock style fits, Summit racing has several units; I like the Crane one that comes with a limit bushing with several steps on it. Last edited by mechanicalman; 09-24-2014 at 04:07 AM. Reason: spelling |
DUI Distributors....very reliable & all in 1 unit. Run 1 in my 400hp K-10 & 600hp jet boat.....Great tech help & high quality.... Ck em' out..... Performancedistributors.com
One of the First
![]() Join Date: Jan 2000
X2 - I run the small distributor on all my motors. Plus designed and put together in Tennessee!
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 09-24-2014 at 01:35 PM. |
Nothing wrong with a HEI that has been hoped up. When mine couldn't keep up I used it as a mag trigger for the programable 6AL box. I went from fouled plugs in days to new looking plugs after a month. Keep things simple and run a HEI untill it wont meet the engine demands any more. This rule really applies if you travel. Make sure that you save all the dizzy guts and put them in the glove box. HEI parts are easy to get if you loose an ignition on the road.
![]() Join Date: Aug 2014
I prefer the MSD pro billet distributors with a msd 6al-2 box. If you don't want to spend that much money they have a ready to run unit that all you need is a coil and not a box. It has the box built into it and has adjustable bushings and springs for mechanical advance and has a built in rev limiter. It only cost around $350 for that setup.
Distributor- http://m.summitracing.com/parts/msd-8360 Coil- http://m.summitracing.com/parts/msd-8202 |
#8 | |
Wel to answer the question I have a 350 with a 4 bolt Main that has a few ad dons done already. Thanks for all the feedback it really helps. She's not putting a lot of hp down right now but I'll be doing a rebuild and hoping to pull 450+ hp out of it and want to get something that will be good for that too
#10 | |
I wouldn't touch that MSD distributor or 6AL digital box with a 100ft pole. A buddy of mine is running the more fancy digital box on his built up camaro an has gone through 3 that's right 3 boxes. Wiring has been checked an checked an checked an its a flaw in the boxes themselves. An now the distributor gave up an he ended up putting a regular old HEI in. I suggest getting a nice Mallory distributor.
#12 | |
#13 | |
#14 | |
As for what distributor, if you don't want the big 6AL box I recommend a Pertronix module. It should handle anything with street compression and no blower. Maybe even those, for all I know. Stock bodied distributor plus a Pertronix II (or III but I've had tach issues with the III) should be all the spark you'll ever need for 99% of engines. And its multi-spark too, which should improve idle a little. Then again, if multi-spark was worth anything, why don't the OEMs use it? Or do they? Did ya know that the LT5 fires two plugs at once in different cylinders? Now you do.
#15 | |
#16 |
The stock HEI will work just fine.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
#17 |
you have no clue what you are talking about with this statement
#18 | |
http://www.jegs.com/i/Chevrolet+Perf...01358/10002/-1 Plus this controller $1141.99 http://www.jegs.com/i/Chevrolet-Perf...58267/10002/-1 Any gen I SBC built to 450+ HP that is as reliable and drive-able as this one, well, it will cost more because it will need stealth ram style fuel injection and lots of expensive hard parts and custom EFI controllers and tuning. Example: for $12, 220.99, you can get 440 HP. http://www.jegs.com/i/Edelbrock/350/...RyUhoC2bDw_wcB Anything cheaper, no drive-ability, and no reliability. I know, you can buy craigslist 450hp 350s all day long. You get what you pay for. Go LS if you want that level of power. |
#19 |
#20 |
400-450 hp is easily obtainable with 9:1 good heads, cam, intake..
edelbrock makes a top end kit for around 2400 shipped to your door. if your rings are good, its a bolt on thing. 10k (as you posted) in a sbc you better be making upwards of 1000+ hp
#21 |
"450 hp easily attainable" out if a 350? I'm not from Missouri, but I have two words...show me.
Jeff
#22 |
X2. Yeah, I'm originally from Missouri.
#23 | |
You have to provide a 9.5:1 compression bottom end for either one, and it has to be worthy of holding up to 410 or 435HP. That means a steel crank, hypereutectic pistons, powdered metal rods, and a 4 bolt main. No, not just "good rings", not unless you don't mind blowing it up. For the roller cam set-ups, you either provide a ZZ4 bottom end or a flat-top bottom end. Plus for the flat tappet one you buy the retro style roller lifters and those are several hundred dollars by themselves. Then, there is the dist (you are going to have to get a good one in order to adjust the curve, like a 350.00$ MSD), carb (400-450.00$), rocker arms, pushrods, timing set, etc. Those kits are based on an optimum dyno tests with hours of tweaking and all the best parts, so you would have to add the dyno-tuning. Yeah, you have to take the engine to a dyno tuner and pay the man, and that don't come cheap. No, you don't just bolt it on and expect to get that kind of power. There are things called "air/fuel mixtures", and "timing curves". And even if you do everything right, you can only make that kind of power while it's on the dyno stand and even then.... you come up 15 HP short of 450. It adds up fast. No, it's not just "good rings". |
#24 |
As others have said it's not as simple and cheap as you think when it comes to bolt on power. There is a lot more involved.
#25 |
![]() Join Date: Jul 2012
I am running a MSD HEI ready to run dizzy and 6a box in my 71. The box made a noticeable difference in low end torque, life of plugs, and driviablity. I have and the box for over a year on this truck and I drive it 60+ miles a day. I don't understand these people that say they are unreliable.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
