Old 09-24-2014, 12:41 AM   #1
Budman56
Budman56's Avatar
Question question about a c30 front k member change out
I have a 63 1 ton that I would like to change out the front k member to disk brakes so I need to know is a 3/4 ton front k member the same as a 1 ton? I have located and purchased a 1 ton 1990 dually rear end so now I have a buddy that has a 3/4 front k member and he says it the same but I dont know. by the way I want to keep the same rims so the front end will need to work with these rims.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 09-24-2014, 08:36 AM   #2
Jeff La
Re: question about a c30 front k member change out
If I recall correctly they are different. I'd measure for sure but I think the 3/4 ton will be slightly narrower than the one ton.
Jeff La is offline   Reply With Quote
Old 09-24-2014, 10:51 AM   #3
63burban
Chevy addict
1 tom front hubs are different to accept the dually type wheels.
63burban is offline   Reply With Quote
Old 09-24-2014, 11:43 PM   #4
Captainfab
60-66 Nut
The '73-'87 C20 front crossmember and control arms are the same as the C30's. You'll just have to change the spindles, rotors and calipers. I don't remember if the ball joints may be the same. I have a complete front suspension from a '73-'87 C20 bolted up under my '66 C30 project.
Very nice score on the disc brake differential. Is that a Dana 70 or 80?
