Old 08-12-2003, 01:58 AM   #1
onelow69
onelow69's Avatar
Temperature guage sending unit
Where is the best location to place the sending unit to the temperature gauge. In the block or in the manifold. It seem that since i switched it from the block to the manifold it seems to read hotter, I also bought a new sending unit from Kragens, could have I recived the wrong part, do they have different ohms for the sending units. Any info would be a great help. Thanks
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
Old 08-12-2003, 08:26 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Left cylinder head
There are a couple of sizes of sending units, depending on several things. But, it shouldn't be a problem to find/install one in the correct position. I installed a new engine wiring harness on mine, and the sending unit, too. Since my original '69 block has later model heads on it, we had to "shop" for the right sending unit, but got it done. My guage works just fine with new wiring and a new sending unit.
I don't know why you'd see a difference in coolant temp, with placement in the intake vs. the block or a head. In my opinion, the hottest place it can go, is right where mine is, between two exhaust ports.
Member Nr. 2770
Old 08-13-2003, 08:30 PM   #3
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
TTT ----
I am also interested in what all of you have got to say about the location of the sending unit. I am going to be putting in my new motor soon and was going to put mine in the intake.
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline   Reply With Quote
Old 08-14-2003, 07:33 PM   #4
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
Call me onelow69. I have some info you wanted.
SOLD 01/18 !!!!!
Old 08-15-2003, 12:43 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think in the head is the best place for it. If you overheat, the head will get hot before the intake, which will give you more time to react before bad things happen. Besides, who cares how hot the intake is...I'm worried about teh actual engine...true, they should be the smae temp, but if everything was like it should be...you wouldn't need the guage.
Old 08-15-2003, 03:46 AM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Listen...GM put it there so...
Then again they did put it in the thermostat housing in the newer Blazer's and trucks.
I think the GM design team was BIG on the 4:20
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
