Old 09-24-2014, 01:59 PM   #1
Jfarns03
Jfarns03's Avatar
Power steering box problems
Recently ive pulled my power steering box from the frame and cleaned it out. I could not believe how much black sludge came out of that thing. In the process of installing it, I noticed when i turn the wheel to the left, it goes about half way. when i turn the wheel to the right, it makes the full turn. I have about 4inches of travel in the steering wheel. This is a very uncomfortable ride to drive down the street. Did i mount the pitman arm in the wrong position (according to a clock) ? Suggestions would really help me out !
A place for everything, everything in its place.
Check out my build thread!
http://67-72chevytrucks.com/vboard/s...43#post6129043
Jfarns03 is offline   Reply With Quote
Old 09-24-2014, 04:18 PM   #2
Wrenchbender Ret
Re: Power steering box problems
You can't get the pitman arm in the wrong position. It is indexed for 4 positions each one 90 degrees different. You probably have the sector shaft in 1 tooth off.
Wrenchbender Ret is offline   Reply With Quote
