09-25-2014, 10:38 AM | #1 |
WTB: 4 flu radiator lower mounts
Hey guys - hoping one of you can help me find a set of the lower clamps bradded to the frame that support the larger 4 flu radiators a lot of the big block or A/C equipped 69-72 truck came with - would buy the two uppers as well if you incidentally have them too....please let me know. Need these very badly for a buddies' truck we are working on....Thank you
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
09-25-2014, 11:02 AM | #2 |
Re: WTB: 4 flu radiator lower mounts
Not sure if you want to go this route or not but when I converted my '71 4x4 to a 4 core radiator I used two upper mounts and removed the "saddles" from them by drilling the spot welds. Then drilled a hole in each and used a Phillips self tapper screw with a low flat head to mount to the rad. support. Also had to notch the rad. support lip because the lower support is larger than what was stock using the 3 core mount.
If interested I have two pair of the upper mounts with rubber cushions. Can bead blast, prime and paint if wanted or just as they are. $40 for the pair plus shipping.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
09-25-2014, 11:08 AM | #3 | |
09-25-2014, 11:18 AM | #4 |
Loves all GMC trucks
The factory 4 core radiator trucks have a relief in the area where the lower radiator brackets go due to their length. Not a big deal as you can notch the area but there is a difference. I think Gary was just letting you know so you wern't surprised if you tried to put them in and it seemed fishy.
Mike If your helping someone and expecting something in return... your doing business not kindness! |
09-25-2014, 11:34 AM | #5 |
"Trucks with Class"
I have full 8-pc sets of new metal brackets and rubber mounts: $60 with a complete stainless hardware set. Plus $10 S/H.
09-25-2014, 12:10 PM | #6 |
You beat me to the reply Mike, thanks for the explanation. The four core mount or saddle being a bit longer needs a small notch cut in the rearward (engine side) of the radiator support. The support has a small ridge of metal that interfers with the longer four core mount. Was not a big deal at all, a little air grinder work and if fit fine. I loose mounted the radiator to locate the mounting area, marked, drilled a couple holes and used the Phillips self tappers to mount. The upper mounts fit fine with the extra radiator width. Hope that helps.
09-25-2014, 12:40 PM | #7 |
Thanks to everybody for your posts and info - I called fellow long time member JQ-72 (you all know him I'm sure) to ask about the notching required etc and incidentally he was standing in a salvage yard looking over a 72 Highlander long box truck someone carried to crush and believe it or not, it happened to have these darn 4 core supports still on it - so he is grabbing them for me as we speak - just one of those lucky days I guess. Very much appreciate you guys jumping in so fast though - thank you
