09-25-2014, 02:48 PM | #1 |
Pitman arm help
Well I encountered a small issue and need some help. I had some play in the steering so i pulled the truck apart and found the pitman arm is very worn to the point were the tapped hole is on longer tapped . I cant seen to find one anywhere does anyone know where I can find one? It's a 55 gmc 2nd series with manual steering. Only numbers I find are 3718863gm4 and on the other side is 1040
09-25-2014, 05:04 PM | #2 |
Re: Pitman arm help
Hopefully someone has one in their pile out behind the shop left over from a crossmember or subframe swap.
I'll have to say, that's the most worn out one I've ever seen.
09-25-2014, 07:02 PM | #3 |
Re: Pitman arm help
Hello S&D. I have a maybe part that if it will work for you, you are more than welcome to have. The part # is close but not the same. This is from a 55.2 chevy. Here are some shots with the dimensions. 1040L is the other #. Center to center is about 6.125. Tapered hole is .645 to .730. Splined hole 1.025 to1.085. Over all length 6.95. And did I say that its painted yellow.
You have to have patiences or you'll be one. |
09-25-2014, 07:41 PM | #4 | |
Re: Pitman arm help
09-25-2014, 07:58 PM | #5 |
Re: Pitman arm help
Hey S&D. Just postage. Its been hanging on my wall for years. It seems like it should fit with the Chevy/GMC parts interchange. If it will fit it needs a new home.
09-26-2014, 09:58 AM | #6 |
Re: Pitman arm help
There you go. That should fit in one of those 5 dollar and something priority mail boxes pretty easy.
09-26-2014, 10:23 AM | #7 |
Re: Pitman arm help
09-26-2014, 01:09 PM | #8 |
Re: Pitman arm help
Hello , PM returned.
Earl from Grants Pass OR.
09-26-2014, 01:18 PM | #9 |
Re: Pitman arm help
Yeah, mr 48chev, thats what I'm thinking to. Arm weights less than 2lbs and should fit in the box.
09-26-2014, 04:40 PM | #10 |
Re: Pitman arm help
Hey again Sanford. Sent another PM to you. Just wanted you to know that the arm is on its way. Hope that it works for you. Good luck.
Earl
09-27-2014, 12:07 AM | #11 |
Re: Pitman arm help
Good deal
"It ain't as easy as Chip Foose makes it look" |
09-27-2014, 07:53 PM | #12 |
Re: Pitman arm help
