Old 09-25-2014, 03:05 PM   #1
dmartin1
dmartin1's Avatar
just some exhaust opinions? 71 k10
hey fellas,just seeing what your opinions are. heres the story.
71 k10 longbed. the body looks ok but is all reality CRAP(cab was in a wreck at sometime and bondo-held together with paint on top) bed is crap also.with an honest problly 2 gallons of bondo on it.
so i am swapping my 1-owner 67 never wrecked almost no rust body onto it(small cab window too )
the engine is the stock 1971 350. it is 100% stock from air filter to oil pan EXCEPT for the headers on it that leak badly.it has 78k original miles(owner kept a detailed log of everything since new in glovebox)
should i replace with new longtube headers or factory manifolds for a 71 k10?
this is going to be a daily kinda truck.real clean.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 09-25-2014, 03:06 PM   #2
dmartin1
dmartin1's Avatar
Re: just some exhaust opinions? 71 k10
the engine has plenty of power, it is surprisingly peppy and quick.will i suffer a big loss going to manifolds in this setup?
65 nova
And more
Old 09-25-2014, 03:51 PM   #3
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Cant beat ram horn manifolds. They're affordable, they flow (arguably) as good as headers and you don't have to monkey around with tightening them for leaks all the time.
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 09-25-2014, 06:32 PM   #4
mrein3
mrein3's Avatar
I agree 100%.
I'd get factory manifolds (center dump on 4wds) and order the Heartthrob exhaust "kit" made for the truck. I put their exhaust system on my 4wd and it fit like a glove.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-25-2014, 09:45 PM   #5
seattle gmc
seattle gmc's Avatar
Hey mrein3, are you ruuning your factory heatriser? I have the hearthrob kit, but i have some clearance issues running over my np205 transfer case. I Think the hearthrob kit is good but i need to get mine figured out, its bascily resting on the transfercase?\.
1970 GMC K2500 aka MaTeR
2007 Chevy Silverado 1500HD Classic
seattle gmc is offline   Reply With Quote
Old 09-26-2014, 01:29 PM   #6
mrein3
mrein3's Avatar
No. My truck was a mutt when I got it. No heat riser. In fact, the cowboy that put it together found two "RH" rams horn exhaust manifolds and used them. The "LH" and "RH" must be symmetrical because that kit bolted right up and fits like a glove.
It has been at least 12 years since I installed that exhaust but I do remember there being not a whole heck of a lot of room for the side that goes by the transfer case.
'72 Malibu hard top
Center City, MN
Old 09-26-2014, 01:39 PM   #7
Lee H
Lee H's Avatar
Agree with others, stock manifolds for a stock setup and possibly a daily driver, maintenance and worry free. Check out your local muffler shop before ordering an exhaust kit. Some are total hacks and some put out really fine work.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-26-2014, 04:12 PM   #8
1972GMCsierra4x4
I would personally go with headers myself. They flow better than stock manifolds, and plus there's always the ability to say it has headers on it
1972GMCsierra4x4 is offline   Reply With Quote
Old 09-27-2014, 02:36 AM   #9
mechanicalman
If you are going with a/c, and go with headers, go with hookers: they are the only header manufacture that I have found that offers an a/c bracket for factory A6 compressor on headers, and I'd be afraid to try to use it on other headers than hooker as the bracket is a tight squeeze even on the hookers but it fits and the compressor bolts up as it's supposed to.
If you go with manifolds, and still want performance, check these out I think they are a cut above stock. You will have to go with 69 and up style alternator bracket though on these or the headers. 67-68 had alt bracket built onto the L manifold.
http://www.speedwaymotors.com/Tru-Ra...Iron,3823.html
Kinda pricey, and I would not expect "bolt on" exhaust pipes to fit them. So if you use these, you will have to get custom exhaust.
mechanicalman is offline   Reply With Quote
