Old 09-25-2014, 03:40 PM   #1
ACII
which fuel pressure regulator ???
Hy all .....
for my LS1 i am looking for a fuel pressure regulator.
what do u recommend about the boost / vacuum ratio ???
it is a must to have a 1:1 ratio or better to go with 1:1,7 ??
My current setup is a stock engine
Achim
ACII is offline   Reply With Quote
Old 09-25-2014, 07:35 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: which fuel pressure regulator ???
The 1:1 is the only one you'll want to touch. With the 1:1 ratio, you're supplying the increased pressure and allowing the injectors and your tune to handle the "specifics" of the fuel requirements (I'm assuming you have large enough injectors to supply this).
The 1:1.7's are usually something you see used on less "tune-able" cars. Its kinda like those "boost fooler" and "fuel cut defender" things you see, in the sense that its designed as a shortcut for cars that don't (or can't ) be setup with "proper" fueling.
IF for example; you were working on an FC Rx7, which due to its 80's technology and simplified fueling and computer systems, would require a full stand alone ecm and fueling system to "really" start making HIGH hp. The 1:1.7 would allow you to ramp the feed rate to stock injectors, increasing their output by a % and delivering a "calculated" increase in fuel. The idea being that you can attempt to deliver a "safe" amount of fuel...even tho you might not have the proper control of the fuel map/curve, or air metering devices to actually run it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
