Old 09-26-2014, 12:02 PM   #1
csfdfirefighter
Mallory HEI distributor Help.
Hey guys, so I have been putting off figuring out why my 69 C10 hasn't been starting.. Traced it pack to the distributor. Unscrewed the four screws on top and found that the yellow wire was severed. I was barely manipulating the top to see how i might replace it and the red one broke as well. I am semi mechanical but mostly on new cars.
I have been learning from the great help you guys have been giving me. Can someone tell me or show me where I can find directions on how to replace this?
thanks so much.
csfdfirefighter is offline   Reply With Quote
Old 09-26-2014, 12:23 PM   #2
csfdfirefighter
Re: Mallory HEI distributor Help.
ok quick update: I pulled the severed prongs out and removed the coil from the cap. Can I just solder them back on or should I buy new prongs?
Old 09-26-2014, 05:38 PM   #3
Zeke's Garage
Zeke's Garage's Avatar
You should be able to pull the prongs out and re-solder.. odd that they would be so poorly connected, but you never know..
'67 Chevy Stepside
250 Inline 6
Megasquirt Fuel Injection
T5 5 speed conversion
Ferric Oxide impregnation throughout
Zeke's Garage is offline   Reply With Quote
Old 09-27-2014, 07:46 AM   #4
jaros44sr
jaros44sr's Avatar
Seems to me, you re trying to pull the coil pack out with the cover, coil should stay in distri.cap as you take the two screws out to remove the cover...
I don t like to solder, as it can make the wires brittle, a good crimp should hold, just unplug coil from cap, then remove coil if need be
New connecters is my vote
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
