LQ4 intake/harness help/advise
Well I had a complete 01 LQ4 out of an 01 Denali fall into my lap. It is a complete motor minus the wiring harness, ecm and of course no pedal or TAC. I was told the motor was no good so I tore it down and found it had a spun main bearing. I found a fresh rebuilt 06 LQ4 short block for CHEAP and swapped the heads and everything else over and now it is sitting as a long block. I have been trying to educate myself on the Vortec motors and have come across several differing opinions (surprise surprise!!!)
Anyway to get to the questions and to see if I can clear the mud out of my head a little bit here goes. I have everything I need to take it back to a complete 01 style motor but have been looking for a wiring harness, ecm, pedal and TAC that will work and get it running. From what I have seen the 01-02 LQ4's seem to be a pain in the a$$ since they are what seems to unique to those years. And to add to it the required parts to get it running (ecm and TAC) appear to be much higher priced. I was thinking if I could find a complete 06 intake with fuel rails, injectors and TB then I could get the less expensive ecm, pedal and TAC. Does this sound like a good route to go or should I be looked at doing something else. I am trying to put this motor back together as inexpensively as possible because cost is an issue. Oh and I will be looking to put a 4l80e with it.
If you ask the question. Make sure you are ready for the answer. 69 C-10 Longbed (In Progress) Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=568171 |
meowMEOWmeowMEOW
Re: LQ4 intake/harness help/advise
was the original 01 an iron-head motor?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
No the motor had aluminum heads. That is another thing that is making me wonder because I know the 01 should have had iron heads. I will get a pic tomorrow. I was also thinking that the throttle body should be a 4 bolt with a 2 plug sensor but it has 3 bolds and a single sensor plug and the fuel rails are return type rails. There are several things about the motor that has me scratching my head.
Early DBW/Traction Control, This set-up was used in '99-'04 Vettes & '01 & '02 SUV/C3 Sierras with Traction Control, Unless you have the PCM, TAC & Pedal...Don't use this set-up.
#5 | |
meowMEOWmeowMEOW
If thats the case, the 3 bolt TB and aluminum heads make sense. In that situation, your best bet is to find; the TAC, ECM, TB and Pedal all from an 02-04 truck or van with DBW and a 4l80e (hint, look for a G-van). This will get you a matched set of components that will fit on the 3 bolt intake, run together, and be tuneable.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Tarzan! Hello neighbor!
I am in Ft Worth! Have you checked with the WY on Mansfeild Hwy, First one, left side as your heading south! they used to have tons of vans and have been real good to me when I was doing my swap! Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#7 | |
To the OP, If you need a TAC, let me know, I have some. The pedal is the same from 01-05 so they are easy to find.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 09-27-2014 at 10:51 AM. |
meowMEOWmeowMEOW
My setup was a late 03 2500 time warner van
#9 | ||
I will be needing an ecm with wiring harness, TAC with matching pedal and harness for either the 2 plug TB or 1 plug if I find one that is reasonably priced. Does anyone see an advantage or disadvantage to turning this into a 03-06 style motor since I will have to get all the parts above anyway? And what about the fuels, should I leave the return type or go with the returnless style?
meowMEOWmeowMEOW
I prefer return style, just for the ease of switching rails, or adding an aftermarket/external FPR unit should you decide to go FI.
Not to hijack... Are you absolutely positive it was a van???? I would have paid you good for a copy of that tune a few years ago. Not sure if you are aware of it, but that is the ONLY factory tune with the 03-07 DBW and also with the 12v A/C request versus the serial data A/C that the trucks come with. Just recently HPTuners added the option of switching the request signal, so its a moot point now, but its cool to actually know someone had one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#12 | |
Whatever rail you go with, be sure your tune matches it. It can be changed with HPTuners and any tuner should be able to do it, juts making you aware of it.
#13 |
Thanks for all the good info and helping to educate me on the new stuff. I'm sure as it all goes together I will have many more questions. I think I am leaning toward staying with the return type rails because if I'm correct they have the fuel pressure regulator built into them.
Ls1nova>> do you have a all plastic TAC that will work with the blue/red pcm and the 2 plug throttle body sensor that you would be willing to part with??
#14 |
Yes, I have the all plastic TAC module. I bought it trying to make the 03-07 TB work, but it didnt work. I was trying to get the A/C request to work. Pretty sure I have the PCM too, but its for a 5.3 with a 4l60e, so it would need a segment swap to run the 4l80e. I'm not at home right now, but will be back in a week if that works for you I can look for all of it when I get home.
#15 | |
#16 | |
Tazman, I do have a Harness from a '02 Sierra C3 LQ4/4L65E. If LS1Nova has the PCM & TAC you will be in good shape! |
#17 | |
meowMEOWmeowMEOW
Not sure if you remember, but I had to trade you that all plastic DBW pedal that I picked up for the metal one? That was when I put it all together. The ECM was off of ebay, and I can't prove what it was from. Like most ebay ads, it said something like "ECM 2002 2003 2004 Chevy GMC silverado Van " lol.
#18 | |
Again thanks for all the information and help.
#19 |
It's alsways something.....
![]() Join Date: Nov 2008
[QUOTE=ls1nova71;6858738]Not to hijack... Are you absolutely positive it was a van???? I would have paid you good for a copy of that tune a few years ago.
ls1nova71- On my shelf, I have the ECM from a 2003 van that I bought the LQ4 from.It still has the factory tune. Do you need it still?
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
#20 | ||
[quote=chuckmc8;6859150] Quote:
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 09-28-2014 at 10:52 AM. |
#21 |
For the guy with the time Warner van PCM, can you email me the file from it?
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
#22 |
Anthony, he didnt get the PCM with it. Got one off eBay, so most likely a truck PCM.
#23 |
Just asking if he has a PCM that works with manual ac I could get the file for reference. Not really caring what it came from but just that it works.
