WTB: np205 shifter, BB power steering, etc
I am doing a big block and 700r4 swap on my 71 k10 and am still trying to track down a few parts.
I need the following: - Shift lever, bolt, washer and short curved rod for a np205 transfer case. Bolt needs to be 9/16 thread. A lever from a th350/np205 setup should have the right bolt and parts. - Big Block power steering pump, pulley, brackets and reservoir - Clutch rod cover plate and screws for firewall - Automatic pedal assembly - Tall auto trans hump/cover - Passenger rear cab frame mount. The big bracket that is riveted to the frame. Please let me know if you have any of these and what you want for them shipped to 83709. ![]() Last edited by Gawdly; 09-26-2014 at 03:40 PM. Reason: Format |
![]() Join Date: May 2011
Re: WTB: np205 shifter, BB power steering, etc
I should have a few of those items I try and get a picture tonight.
![]() Join Date: Dec 1999
I have a painted lever with bolt and washer, no short curve rod. Also have the tall auto hump cover. 125.00 shipped.
"Trucks with Class"
![]() Join Date: Jul 2000
BB PS Package w/pump pulley (less crank pulley): $175 shipped. Add $50 for crank PS pulley.
Just like to part out trucks!!
I have a AT brake pedal setup and clutch hole cover and I think I have the transfer case shift bolt
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Carpe manana
![]() ![]() Join Date: Dec 2010
I have a chrome 71-72 NP205 shifter to spare...not the attachment hardware though
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#8 | |
I have a crank pulley coming from Desert Rat off an AC truck, is there an add on pulley I need? I thought it just ran off the crank pulley. |
I think I have everything but the shifter bolt and the BB ps parts. Everything is from a blazer so cab mounts and shifter I am not sure if they are correct and the s link is a flat bar my 71 is that way. Cab mounts from a 72 blazer. I took the picture of the throttle pedal thinking you needed that I have a better brake pedal assembly with the pad still on the pedal and I can get you a picture of that if needed. I also have the clutch block off plate but do not have it pictured. 225 shipped for everything.
"Trucks with Class"
Yes, it does come with the above items. There is a stand alone PS crank pulley and it is a little hard to find, because they usually go with the motors.
Carpe manana
Are you parting with the K10's original motor and if so is it a 350? Thanks, Pete
#13 | |
I'll take the power steering setup, skip the pulley for now. PM me with price and PayPal info please. Thank You! |
#14 |
#15 |
Carpe manana
Thanks for reply. Good luck with the build.
#16 |
#17 |
#18 | |
#19 | |
![]() Join Date: Jun 2005
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#20 |
$42 shipped for at brake pedal and clutch cover plate. Thanks Randy
#21 |
#22 | |
#23 |
#24 |
Here is the parts I told you about
#25 |
Can you verify for me that the bolt is the 9/16 thread version? I guess there is a 7/16 version too (have one, doesn't fit). And the tall hump is auto 4x4 correct? look as good as the one 1rippen 6 posted? If so I'll take all of it for $125. Can you send it along with the pulleys I already bought?
