Old 09-26-2014, 04:22 PM   #1
brown7373
brown7373's Avatar
Windshield Water Leak?
We had a very heavy rain the other day, and my truck was parked outside. When I got in it, I had some water on the floor. When I drove away, it started pouring from under the dash, right under the A/C controller and under the lighter. It increased when I accelerated or turned corners. I think it is coming mostly from the passenger side. I used to get a leak on that side and it would soak things in the glove box. My windshield has a new rubber molding with the stainless trim inserted. When that was replaced, we checked around the edges and it all looked sound.
Anyone had water leak around a new windshield seal (gasket) before? I don't think that rubber seal is supposed to get any cement, is it?
brown7373 is offline   Reply With Quote
Old 09-26-2014, 04:48 PM   #2
n33k0
Re: Windshield Water Leak?
My '72 has a similar leak. I noticed a small pool of water forming where the dash meets the bottom of the windshield, and there is a small hole in the metal beneath the windshield rubber that lets the water drip behind the dash panel. The windshield was replaced a couple years ago by the P.O. so I'm not sure if that rubber counts as "new" (it's certainly not 42 years old! )
I am planning to poke around behind the grill that sits beneath the windshield wipers, I've read that area is prone to clogging and rusting out leading to leaks inside the cab. Not enough daylight to get all my projects done!
n33k0 is offline   Reply With Quote
Old 09-26-2014, 04:55 PM   #3
BLT gmc
Yes, the windshield and gasket are good places to start. I would also inspect the plenum from the air induction and the cowl area very close. These areas are prone to rot and let water in the cab when the truck is just setting there. Good luck, Bruce
BLT gmc is offline   Reply With Quote
Old 09-26-2014, 05:33 PM   #4
70shortfleet
70shortfleet's Avatar
Dry everything off, get inside and have someone squirt water with hose and see if you can find the leak!
70shortfleet is offline   Reply With Quote
Old 09-26-2014, 06:30 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: Windshield Water Leak?
Top of windsheild corners just about aways leak. Put a little sealer in them and be done with it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-26-2014, 08:13 PM   #6
brown7373
brown7373's Avatar
I think I will try some sealer in the upper corners and maybe the bottom corners. I have sandalwood carpet, that now has a huge discolored spot!
Old 09-26-2014, 09:52 PM   #7
BruthaMan
US Army Veteran
BruthaMan's Avatar
Another place to check is the wiper motor seal. There is a seal that goes on the outside of the cab, where the wiper motor comes through the cab. If that seal is missing, cracked or gone, it will leak in, run down the left side and poll on the passenger side floor. Replaced mine a few months back and solved that issue, but I also have windshield leak at both top corners too.
BruthaMan is offline   Reply With Quote
Old 09-26-2014, 11:29 PM   #8
Sklptrljay
Sklptrljay's Avatar
I had the upper corners of the windshield leak on my old truck, and on my current truck I had a leak from the grommet for the antenna.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 09-27-2014, 05:46 AM   #9
GuyO
GuyO's Avatar
My antenna grommet leaked badly and next to it (under the valence) the factory used some putty at the joint below the windshield that cracked. The crack was about 2" long and about 1/8" wide. Be sure to check that area as well.
GuyO is offline   Reply With Quote
Old 09-27-2014, 07:04 PM   #10
JimKshortstep4x4
Top corners as has been mentioned are prone to leak. In the service manual, instructions for installing windshields, after installation, state that sealant is to be applied at both top corners. A 6" bead is to be applied in both directions from each corner.
I have seen lots of original windshields that don't have the sealant in the corners and they leaked!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-27-2014, 07:09 PM   #11
dsy1
I have a leak also, which gets the inside of my glovebox very wet. I assume this rules out the wiper motor and A/C-heater box, since those would be too low. What else could could let in enough water to pool in the glove box liner?
dsy1 is offline   Reply With Quote
Old 09-27-2014, 07:32 PM   #12
Sklptrljay
Sklptrljay's Avatar
The windshield upper corners will allow water to carry into the dash and glove box. Ask me how I know
Old 09-28-2014, 09:33 AM   #13
brown7373
brown7373's Avatar
My glove box gets soaked too. Any recommendations on what sealer to use? I have seen 3M windshield sealer. Doesn't the antenna grommet just allow water into the cowl, same as the slots by the WW wipers? Speaking of WW wipers, what was Chevy thinking by putting the wiper motor & washer on the INSIDE, under the dash? Talk about a real pain to get to.
Old 09-28-2014, 10:43 AM   #14
sboris
sboris's Avatar
The antenna lead coming in at the base of the windshield on pass side often gets overlooked. Stand on your head with a good light to see that one.
Windshield is probably it, new gaskets don't always fit as well as oem, could require resetting, or maybe a little sealer.
Definitely check that wiper motor as mentioned, thats a BIG hole there..
Looks like you you have a very nice truck, but can we rule out RUST? Couple areas to look for. Again, around the wiper motor, and there is what I call a vertical seam on the drive side, above the fuse panel, and on far pass side that is just under the cowl. Those seems can get moisture Inbetween them and rust. Ask how I know..
The only other areas I can think of are on the firewall and shouldn't be affected by rain...
Hope it's something easy, good luck
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 09-28-2014, 06:43 PM   #15
brown7373
brown7373's Avatar
I didn't consider where the antenna wire comes through at the windshield base. And I will seal the corners and check the WW wiper. I need to replace the washer pump anyway...again
Old 09-28-2014, 08:48 PM   #16
BLT gmc
I have resorted to a garden hose to help recreate the leak. This helps if you can not se an obvious source.
Old 09-28-2014, 10:37 PM   #17
Sklptrljay
Sklptrljay's Avatar
When I said earlier that it leaked through the antenna grommet I should have specified. It leaked from the hole in the dash not the exterior hole on the cowl. To find the leak, I had my daughter look behind the dash while I sprayed the windshield with a garden hose. I couldn't even see a hole for the antenna there, but I guess 9 year old eyes can see just about anything.
Old 09-29-2014, 12:27 AM   #18
808turbo
What kind of sealant do you use. When I removed my winshield it a white putty in the croners. It looked like plumbers putty.
808turbo is offline   Reply With Quote
Old 09-29-2014, 10:58 AM   #19
brown7373
brown7373's Avatar
I am not sure what sealer to use either.
Old 04-08-2015, 03:28 AM   #20
Duelly
Hi, I am new at this site and I have a 1970 CST/10 and only had this truck since last September. We went on a road trip with our truck club I belong to and it had been raining on and off during the day and on our way home at 8:00 I lost all my tail lights and marker lights. One of our members followed me all the way home. It had blew 2 fuses and the fuse box was damp and some rust on the connectors where the fuse connects into. Its been in storage all winter with no electric in the building where it is stored. The ice and snow was halfway up the front of the door. Just two days ago I got the door opened to begain to work on it. but, where do I start? Not sure where the water would be coming in from. Its totally dry now. Where should I start looking for the problem. Hope someone has an answer !!
Duelly is offline   Reply With Quote
Old 04-08-2015, 07:33 AM   #21
R.L.
R.L.'s Avatar
Buy a sealant made for automotive applications, RTV silicone will eat the metal around windows. I used this stuff on a Nova and had to have some body work done.
R.L. is offline   Reply With Quote
Old 04-08-2015, 09:22 AM   #22
LockDoc
The Older Generation
LockDoc's Avatar
Check the inside of the drip rails for any cracking/chipping of the sealant and seal as needed. Also seal along the top edge of the windshield gasket, especially the top corners. It is probably getting into the cab from the body seams at the bottom corners of the windshield. Below is a picture of the problem areas on my '67 Panel that I had to fix. If you take care of the drip rail and windshield gasket areas it should keep the water from getting in until you can do a more permanent repair.
As far as the fuse box, I use a Dremel type tool with a small round stone in it to clean the fuse holders. You can also replace it with one that isn't rusty (means changing the under dash loom) or completely disassemble it and clean the contacts up.
LockDoc
I don't think it is the silicone itself that causes deterioration of the metal but it attracts moisture which causes it.
LockDoc
Leon
Old 04-08-2015, 10:13 AM   #23
57taskforce
All about them K’s
57taskforce's Avatar
Leon, with the windshield in place you probably never knew those holes were there did you?
Tyler
57taskforce is offline   Reply With Quote
Old 04-08-2015, 10:24 AM   #24
Possmguts
Possmguts's Avatar
That comes from this....
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 04-08-2015, 10:46 AM   #25
michael bustamante
michael bustamante's Avatar
it sounds like now is a good time to make sure my cowl area and windshield lip are in good shape and freel of possable waterleakage while the glass and front clip is off
1967custom
michael bustamante is offline   Reply With Quote
