Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-26-2014, 11:13 PM   #1
Blu64c10
WTB radiator crossmember
WTB a straight radiator cross member
Blu64c10 is offline   Reply With Quote
Old 09-27-2014, 09:06 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: WTB radiator crossmember
I am picking up my longbed frame this weekend. I will cut this out for 50.00 .
LT1 Burb is offline   Reply With Quote
Old 09-27-2014, 09:21 AM   #3
Blu64c10
Awesome. Thank you.
Old 09-27-2014, 11:26 AM   #4
chevyrestoguy
chevyrestoguy's Avatar
That is probably the most often damaged frame component on our trucks. I don't know why GM put the large hole in it because people think that it's the perfect spot to install a strap or chain to pull from. As your truck can attest, it's not. Mine was bent, but not as bad as yours, but I was able to use a rosebud and heat it get it back straight.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-27-2014, 02:29 PM   #5
1960chevypanel
If LT1 can't help I have one also
1960chevypanel is offline   Reply With Quote
Old 09-27-2014, 11:11 PM   #6
Blu64c10
I had always thought that maybe my truck had a small front ended at some point but now that you say that I realize it had defiantly been pulled on.
Btw I always like checking out your build chevyrestoguy
