09-27-2014, 03:42 PM | #1 |
62 C-10 Rear end width help.
Just wanted to know if anyone could give me the "total" rear-end width with tires and adequate clearance for a fleetside box. I don't have a box presently and am trying to plan what rear-end width and the back spacing I will need
09-27-2014, 04:12 PM | #2 |
Re: 62 C-10 Rear end width help.
I don't have measurements, but I have 275/60s on 15x8 wheels and they JUST clear without rubbing on the inside or with the outer bedside.
09-27-2014, 04:14 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-27-2014, 09:02 PM | #4 |
Thanks guys, but I don't presently have a bedside to measure. I am building my own frame and I am not going to use the 62" rearend that comes standard. I'm planning on using a 8.8 disc brake out of explorer or a concerted disc brake 8.8 out of a Ranger. I'm planning on running a min of a 12" rim. I will more than likely buy a rim blank and have the stock center refitted for the back space I need. I was hoping someone here could give me just a total measurement.
09-28-2014, 10:56 AM | #5 |
Why are you using such a small rear? At least use a real full size rear. 9 inch, 12 bolt, or the like. A big tire and wheel combination will stress the weak parts. If your build a rear frame, measurements don't count till the final setup, then you get rim backspace. 18x9.5 with 4.5 back space 295 / 45 / 18
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
09-29-2014, 07:39 AM | #6 |
A 8.8 with 31 spline axles with 3-1/4 inch tubes is hardly small /weak apparently your not much or keep up with the drag racing scene. A 12 bolt is a joke compared to a 8.8 the only advantage is it weighs more.I'm simply using the 8.8 because it is plenty strong for any street duty use and it is already plenty narrow for the wheel/tire combo I'm looking to use.
09-29-2014, 09:06 AM | #7 |
Our excellent online 642-832 dumps training programs will lead you to success in the wikipedia We also offer latest Swiss Federal Institute of Technology Zurich and HITACHI with 100% success guarantee. Our selftestengine is rare in IT MICROSOFT |
09-29-2014, 09:33 AM | #8 |
Yup, that's what I was look for, I thought someone here might be able to help me out with that. No problem, I'll get her figured out.
09-29-2014, 11:10 PM | #9 |
60-66 Nut
I'll try and remember to get you a measurement tomorrow.
09-30-2014, 07:54 AM | #10 |
Captain, that would be greatly appreciated.
09-30-2014, 08:14 PM | #11 |
The measurements we did today with some pinch weld grinding is 74" with a little to spare. Im doing 20x9 5 1/4 inch backspacing and 63 1/2 is my max flange to flange.
Hope this helps! |
09-30-2014, 10:31 PM | #12 |
My outside tire to tire is 76 1/2". Tire is pretty tight to the fender, I have trimmed the inside of the fender flange and rolled a bit for clearance. The inside to inside of the fender flanges is 77 3/4". 335 tire on 12" wide wheel, not sure on backspacing would have to dig that up. Good luck, sounds like a cool project.
Kent DRIVE IT HARD, DRIVE IT OFTEN! Short video of Black Betty & a friends 48 Panhead done by my kid. https://www.youtube.com/watch?v=8DlAdfwDQa8 |
10-01-2014, 02:08 PM | #13 |
Thanks guys that's the info I was after, thank so much for taking the effort to help. Greatly appreciated.
10-02-2014, 12:23 AM | #14 |
60-66 Nut
Ok, here's what I came up with.
On my '66 Suburban with 275/60R15 tires on 15 x 8 Rally wheels (3-3/4" backspacing) the outside to outside of the tires measures 74-9/16". This is with a stock 62" width 12 bolt. On a Fleetside bed, the distance between the wheel tubs is 50-3/8". The distance from the inside of the wheel tube to the lip on the bedside is 13-1/2". This makes a lip to lip measurement of 77-3/8".
10-02-2014, 04:51 PM | #15 | |
09-20-2018, 08:29 PM | #16 |
But Found Her 25yrs Later!
I understand them moving out for discs, but why did they keep moving them out even more with the newer trucks.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
