Old 09-28-2014, 09:25 AM   #1
vjjack04
vjjack04's Avatar
frame to SBC bolt in motor mounts
Guys,
I want to change my motor mounts to some kind that bolts to the frame, at the sides then to the engine. I had some weld in mounts but the welds must not have been good and they broke. Is there a good bolt in aftermarket type? The front of my frame is boxed.
vjjack04 is offline   Reply With Quote
Old 09-28-2014, 12:20 PM   #2
_Ogre
_Ogre's Avatar
Re: frame to SBC bolt in motor mounts
what broke? what style did you use? need pics....
the fix could be as easy as taking it to a shop for welding
i'm still a fan of weld in mounts. never had one fail, but i've seen some of those cantilevered kits that look like they'd fail.
i welded a set of similar mounts like these into my truck way back before my latest remodel with the motor and body complete
if you have a stock frame use 2 triangular gussets to the top and bottom frame lip
with a mustII it is easy to come off the x-member
these are in my truk now
shop air compressor timer
Old 09-28-2014, 02:14 PM   #3
vjjack04
vjjack04's Avatar
Thanks for the pictures....Mine were just two steel plates one each side I thin the really need the an extra gusset or side plate....I will just use metal and re-weld them.
Old 09-28-2014, 02:59 PM   #4
OrrieG
OrrieG's Avatar
Photo would help with responses...
OrrieG is offline   Reply With Quote
Old 09-29-2014, 08:24 AM   #5
solidaxel
solidaxel's Avatar
Take a look at Chassis Engineering for a pattern, did you box your frame?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-29-2014, 01:02 PM   #6
_Ogre
_Ogre's Avatar
help us out here vjjack, post a pic to see if what you have is fixable
as a structural engineer i see a lot of stuff that shouldn't be used
