Old 09-28-2014, 12:06 PM   #1
lowridergmc
lowridergmc's Avatar
k5 2wd rear diff
i was wondering if a 12 bolt 2wd rear diff in a k5 is the same width as a 12 bolt 2wd diff in a truck?mine is leaking at the plug welds on the axle tubes,has anyone sealed theese welds?thanks for your info.
lowridergmc is offline   Reply With Quote
Old 09-29-2014, 08:15 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: k5 2wd rear diff
They're the same, but if you pull yours I'd try to seal it. Short of getting it welded up, wonder if POR would stop the weeping?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-30-2014, 04:35 PM   #3
bdiamond
Does it drip or just seep oil around the plug welds? I think most of them have oil/dirt around them. Unless it actually drips I don't think I'd worry too much. You might replace the vent assembly, carb clean the plug weld and then lay the paint to that area thick.....
bdiamond is offline   Reply With Quote
Old 09-30-2014, 11:25 PM   #4
lowridergmc
thanks for the replies.i will pull the diff out and clean it up and go from there
