Old 08-13-2003, 03:48 PM   #1
Earl Junior
Cadillac power
Earl Junior's Avatar
Talking What cooling problem?
I had this all set to post when the board died. This is take two.
I was having a problem keeping the caddy motor cool. A new thermostat, water pump, radiator, cap, and a system flush didn't help. So I looked to get rid of my flex fan. But, damnation, these things are expensive!
After pricing dual electric fan setups for well into the $400 range, I decided to try the local junk yard. I found a Nissan dual fan setup that I though was going to work great, but one of the motors had a a bolt stuck in the housing.
I decided to use a pair of Flex-a-lite 13-inch s-blade trimline fans ($159 for both from Summit), and a pair of temp regulators from Schucks ($15 for both). I set one fan to kick on when the gauge hits half and the other when it reaches three-quarters.
I have as good, or better, a set-up than many of the high dollar dual fans and for about half the price. The installations was easy, and I think it cleaned things up under the hood a bit.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style.
--Scott Adams author of Dilbert
Earl Junior is offline   Reply With Quote
Old 08-13-2003, 03:48 PM   #2
Earl Junior
Cadillac power
Pic #2
Old 08-13-2003, 03:49 PM   #3
Earl Junior
Cadillac power
Pic #3
Old 08-13-2003, 03:50 PM   #4
Earl Junior
Cadillac power
Pic #4
Old 08-13-2003, 04:03 PM   #5
jhwkns
Registered Cruiser
jhwkns's Avatar
Nice! How well do they cool?
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 08-13-2003, 04:07 PM   #6
Earl Junior
Cadillac power
Great! It was 100 degrees here last week and the temp gauge went down (!) after the second fan kicked in. Before it would have boiled over and left me stuck somewhere.
Old 08-13-2003, 04:55 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Hmmmm...
I have one I mounted on the outside as a pusher. I'll be hooking it up to the 2 sensors on the heads, and also to a manual override toggle on the dash.
You did use relays didn't you?
Looks like a nice job there.
Old 08-13-2003, 05:42 PM   #8
Earl Junior
Cadillac power
Oh yeah.
After I blew three fuses...
Old 08-13-2003, 06:19 PM   #9
Longhorn Man
LOL, at least you figured it all out!
Old 08-13-2003, 06:49 PM   #10
crazy longhorn
Fabricate till you "puke"
I have dual 14" flex a lites on the longhorn, & they work pretty slick. As long as the truck is moving,the fans dont need to run(sb runs cool). My shroud is homemade, & 1 fan was pirated from a wrecked ranger......$84 for the other fan, & a few skinned knuckles. I need to set up relays, & thermostat controls(both fans are fused, & just wired to a toggle for temporary). the fans sure do "cleanup" the eng compartment.......space looks pretty tight with your caddy! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-13-2003, 06:52 PM   #11
Jwill41
Jwill41's Avatar
Very nice setup. Those look just like the Hayden fan I used. Mine is a 16" mounted in the shroud with adjustable controller. Works great.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-13-2003, 11:56 PM   #12
Blue4x4
Blue4x4's Avatar
nice install job. What year nissan?
Blue4x4 is offline   Reply With Quote
Old 08-14-2003, 12:17 AM   #13
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
A word of advise. You better find a shroud or some other way to mount those fans to your radiator. Those plastic things that you are using to hold the fans will eat a hole write in your radiator core. It happened to me and several other people I know. Then you will be another couple hundred bucks. That is why we sell the shrouds that I designed for our trucks. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 08-14-2003, 03:37 AM   #14
72gmcshorty
72gmcshorty's Avatar
Do any of you run fans on a big block motor? I have been looking for some very thin fans ( i have only about 4" from rad to alt pulley). The thinnest I've found are off a ford taurus 94 ( they have nice dual fan setups)
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 08-14-2003, 03:48 PM   #15
Grim Reaper
Tho hot jusk yard score right now is the dual fan set up out of a 95 or so Ford winstar. It has a shroud and with some L brackets it can be easily mounted like the stock shroud. I'm hunting one for my 88 454 burb right now. Damn Autzone fan clutch doesn't work any better then the original that was shot and I start to overheat with the A/C on in drive. Going to go electric and take this POS back and get my money.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-14-2003, 04:38 PM   #16
crazy longhorn
http://www.flex-a-lite.com/auto/trimline.htm the trimline fans should fit your space. My sb is in I 6 position, so i have enough room to darn near play basket ball tween the fans & waterpump! Well, about 8-10" clearance anyway. I have a pair of the 114's on a homemade shroud(a steel shelf for a shroud).....it sounds crude, but fits & looks good. The fans real tight in the center, with about 1/8" space between the pair. The shroud has brackects welded on , to bolt to the original shroud mounting points(not to the steels on the core). Im not sure on the BB, but they keep my 383 between 180 & 190 on temp. Good luck,crazyL
