Disappointed with performance of vintage air cleaner
I wanted a vintage look for the 283 in my '53 and a few weeks ago I found an early 60's air cleaner at a swap meet. Part throttle response is flat and it doesn't pull as hard at WOT. Runs great with 14" round air cleaner in pic #2. Carb is an Edelbrock 500 CFM on an Edelbrock EPS intake.
![]() Join Date: Jul 2007
Re: Disappointed with performance of vintage air cleaner
that is the reason that guys pulled the stock ones off and put an aftermarket open one on their car in the first place.
That long snorkel with the little 2x2 opening is there so the engine is quieter going down the road and you don't hear the rush of air you hear with the open air cleaner even with a little 283. That keeps non performance drivers happier as they hear less noise inside the car. With a stock 283 with a 2 barrel I'd think the performance you didn't feel you cwere getting was more due to the lack off noise from air going in the carb with the stock air cleaner rather than seat of the pants performance loss though. In other words it didn't sound as fast as it did with the open air cleaner.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 09-28-2014 at 08:55 PM. |
Remember in the old days when we used to turn the air cleaner cover over to get the same effect? My ol' man musta chewed my butt 50 times for that.
Old Crow '54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ |
![]() Join Date: Mar 2012
Shape pf filter can is different, air entry into carb is different. OEM can works best with OEM carb. Spacer between can and carb likely will show a difference.
Put water manometer or sensitive vacuum gauge on canister and watch what happens inside can while driving. Any vacuum at all indicates restriction and can drastically changes fueling. |
My 64 chevelle came with the stock one, but with the snorkle cut off. another old schoold trick was to cut a second hole in the back side. Off road racers in 64-65 had one that had a plenum thru the firewall into the cowl vent, early cowl induction.
Old crow, my memorie is that on some Qjet applications you needed to turn it upside down to get the vacuum secondaries to open.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Yeah, Orrie, you may be right about that, but as a kid all I cared about was the sound.
Then I spent 6 years working on GM motor homes and learned about the hidden spring adjustment for the secondary air flap. The problem we found mostly was the air flap not opening, not the actual secondary blades. Back off on the spring and the flap would open, even with the stock air filter in place.
#7 | |
I agree, that's why I wanted it. I have a taller element for it that gives me about a half inch gap between the base and the lid. I'll see if that gives it the extra air I need. I'm just outside Denver a little higher than a mile high so air is at a premium here.
It's funny but in the time period you are trying to emulate with the "look" no self respecting hot rodder would have left that stock air cleaner on an engine he stuck in an early truck.
I'm no fan of that all too new should be under the hood of a mid 70's Camaro one either though.
My wife's '54 panel came with a little paper element type filter on the carb. I had a stock oil bath cleaner laying around so I cleaned it up and put it on the truck. Drove it home and back to the shop and put the paper filter back on. Runs much better with the paper filter as opposed to the oil bath.
![]() Join Date: Aug 2010
If you want the old look how about a Technostalga 8500 Retro Cad / Olds air cleaner.
You can get one from Speedway Motors for $128.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#13 | |
#14 |
The Retro Cad unit has a 14"x4" paper filter in it and is designed for the Edelbrock , Holly , Q-Jet & Demon carbs.
Its all steel and has a relief for an HEI distributor . Opps my bad it's $ 128.99 from Speedway ![]() Go with plan B
#15 | |
I could stick my 14 X 4 K-N Filter in it! ![]()
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
#16 |
#17 |
Here is what I used when I had a 2 bbl Rochester on it a couple of months ago. I also replaced the oil bath element with a paper one. The two openings up front bring in a LOT of air.
( never mind the incomplete nature of this pic, I just did not have any pics of the engine complete with this air cleaner ) ![]() |
#18 |
In the mid to late 60's there weren't a lot of aftermarket parts like there are today. You would have most likely had a chrome Cal Custom air cleaner, about 10" in diameter, with a white filter. An aluminum one (Cal Custom) if you were bucks up or a shiny Corvette or GTO air cleaner, the ones with the louvers around the side. Never would you see that Cad in the 60's that was more of a 50's thing.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
#19 | |
The only advantage would be they would project the noise forward, rather than rearward toward the firewall (like some other intakes do). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#20 | |
#21 |
You want the snorkle air cleaner look and more air, just break out the hole saw and put some holes on the underside close to the edge all around the base.
#22 |
That snorkle in Post #1 will feed a performance type 350 no problem. I'd guess that there is something else coming in to play if it seems to be restricting a 283.
#23 |
like the air cleaner not allowing wot?
check your linkage to see if it will go wot
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#24 |
You sir, are correct. I've been running around with a blown electric choke fuse with the choke only 1/3 open. I must have shorted the choke terminal while playing musical air cleaners. Is my face red! Vintage air cleaner runs as well as open element air cleaner. I led you guys on a wild goose chase but we got to see some great pics.
#25 | |
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
