Old 09-29-2014, 02:21 AM   #1
bpmack16
would I have to tub out my 1972,
I have a line on a set of 20x12inch rims so my question is dose that wide of a rim require a mini tub or can I run them on stock? The tires on them are 31x16 20 but that dosnt have to stay that way I am more consirned with the rims fitting.
bpmack16 is offline   Reply With Quote
Old 09-29-2014, 03:32 AM   #2
bpmack16
Re: would I have to tub out my 1972,
This is actuley what the guy has.
Fronts: 20x8.5 with a 18mm offset. Front tires are General Exclaim UHP 245/40 20 with only 8,000 on them
Rears: 20x12 with a 6” offset. Rear tires are Mickey Thompson Sportsman S/R 31x16 20. Some tread left but not that much.
I don't care about tires I will get new ones but with the rims fit?
Old 09-29-2014, 06:42 AM   #3
PGSigns
PGSigns's Avatar
I don't think that rim will fit. I'm sure others will chime in but with it being centered that is a lot to the outside. Could not find that tire to look at the section width.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-29-2014, 07:28 AM   #4
bpmack16
I am not concerned with the tire size because I'm going to put other tires on the rims. Just want yo know if runs will fit and with what tire
Old 09-29-2014, 08:50 AM   #5
Pro Performance
Pro Performance's Avatar
The 12" wheel will not work in a stock tub, and would require them to be widened. Also, with that backspace, it would require the rear end to be narrowed.
Pro Performance is offline   Reply With Quote
Old 09-29-2014, 09:03 AM   #6
bpmack16
Well I have a line on billet specialty's in that size for $1,800 any one want them. For the set of 4
