Old 08-13-2003, 04:15 PM   #1
GreenMystChevy
Rockwell 221- shift pattern?
I had it written down somewhere but I lost it.
I am also assuming that my SM465 has the pattern of
1 3
2 4
Never owned a four speed or a 4x4 for that matter.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 08-13-2003, 04:29 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's the shift pattern
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-13-2003, 04:30 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
And yes that is the pattern for the SM465, with reverse being down and to the right, i.e. next to 4th.
Old 08-13-2003, 06:02 PM   #4
GreenMystChevy
Thanks!
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 08-13-2003, 06:59 PM   #5
1969 GMC
1969 GMC's Avatar
does the GMC K1500 in your profile have the rockwell?
if so, thats a little weird...should have the 205.
i have been under the impression that 69 was the last year for the rockwell, and also teh first for the 205.
if you do indeed have the rockwell, it can be a bit tricky to shift outta 2wd. also, when filling with gear oil, park sideways on a hill with the drivers side being up higher, that way you can overfill the case a bit, good "oops" insurance
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-14-2003, 12:36 PM   #6
GreenMystChevy
yep, that's what's in the 4x4. Probably wasn't the same tranny that came from the factory because I know it's been messed with. The front axle is also a drum brake setup even though the truck is a '72. Go figure.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 08-15-2003, 12:37 PM   #7
1969 GMC
1969 GMC's Avatar
is the floor hacked up? a '72 should have the original np205 shifter hole on the passenger side of the transmission shifter. the rockwell hole is on the driver side of the transmission shifter. they could have swapped the high humps too, though, since it seems like someone got creative with swapping parts to and from your truck.
1969 GMC K2500
1996 Honda Accord
Old 08-15-2003, 12:51 PM   #8
GreenMystChevy
Nope, the tranny hump must have been replaced because all is well with the holes. And yes, the shifter is on the the driver's side like it should be with the Rockwell. These suckers are noisy!
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Old 08-15-2003, 11:35 PM   #9
breeh
Recovering 67-72 Addict
breeh's Avatar
Let me solve this mystery for you but I am only going to give you some clues. Just for the record though, I never meant it to be a mystery.
1) I use to own GreenMystChevy's truck
2) Take a look at my signature block
GreenMystChevy, if you need to know anything about that truck I will be happy to tell you. I know exactly what you have
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
