09-29-2014, 06:29 PM | #1 |
Frame building!!
Where can i find some layout measurment for a 3100 frame? I have really been thinking of not using the full frame on an s10. But to only use the front clip then build the cab section with 2x6 and then the rear with 2x3!! Anybody done this??
09-29-2014, 06:59 PM | #2 |
Re: Frame building!!
put the model and year in your signature and you will never leave this important info out again
the factory assembly manual will have bucu measurements and is very helpful for getting a truck back together you can buy the fam at any parts supplier
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-30-2014, 11:14 AM | #3 |
A320 Pilot/USAF Retired
Its a little hard to read but this might get ya started.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
10-01-2014, 09:46 PM | #4 |
I cant seem to find much on the difference between the extended cab frame and long bed frames! I need to track down as much info as possible!
1954 Chevy 3100 -- In the work to be layed out |
10-01-2014, 11:43 PM | #5 |
chuckDriver were did you get that picture from? is that from the assembly manual. I just Pick up a 55 59 manual and don't see that picture.
Thanks, Rawraw |
10-02-2014, 12:33 PM | #6 |
10-02-2014, 05:30 PM | #7 |
That pic looks like a bigger truck, the 1/2 - 3/4 tons have a straight flat front main rails.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
10-02-2014, 05:35 PM | #8 |
FAM sec 2 sheet 24.00
10-02-2014, 05:53 PM | #9 |
Lower right corner shows "3100"
Yep it's also in my FAM sheet 24.00.
10-03-2014, 12:55 AM | #10 |
OK, tomorrow I go out and look at mine, I could have sworn the front rails were horizontal and parallel....
10-03-2014, 02:06 AM | #11 |
Orrie, my recollection is like yours, but mine were amputated in 93 so I haven
t seen them lately. |
10-03-2014, 03:04 PM | #12 |
It is slightly arced, the FAM drawing is exaggerated. I suspect might have to do with not stressing the frame between the spring mount points. Unless you slamming the truck real low, building it straight would not be an issue.
10-04-2014, 01:02 PM | #13 |
now that michiganjames has his year and model in his sig... 1954 Chevy 3100
above info is for 55-59 3100, maybe some of the ad guys will chime in not even sure if ad trucks have a FAM
