Which transmission
Good morning,
Well I have come to the conclusion that is time to pull the I6 and 3 speed and replace with sbc and automatic. I just got the motor built, should be close to 370 Hp, just a weekend cruiser. What would you guys recommend for the transmission? I found a donor truck about a year ago, that I got the steering column, linkages, crossmember, and peddles out of. Thanks in advance. |
Re: Which transmission
If you're going to just cruise and enjoy then an overdrive trans is probably what you want. TH350s are fun around town and backroads but they get annoying on the highway. I've been looking at Bowtie Overdrives' website. They have some performance oriented stuff at not too bad of a price.
John '71 Cheyenne 10- In the works http://67-72chevytrucks.com/vboard/s...d.php?t=638156 |
Vintage 4x4s
find a my6 and make 4ott
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Your needs will really dictate what kind of tranny you get. Rear end gears can help compensate for the lack of OD in a 350 or 400, but then you will have a truck that isn't too keen pulling from a stop light. Really decide what you prefer your truck to accomplish, then your transmission choice will make a lot more sense.
I agree with leftybass. I forgot to mention rear end ratios.
It's all about application: You want a beast from red light to red light, or do you want top end performance?
The truck has 3:73 gears right now. Plan on keeping them, that a pretty nice all around gear.
Senoir Member
I have a similar setup in the 67 4wd. Leaning toward a 700R4.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
Weekend cruiser- 700r4, 2004r, 4l60e: all overdrive transmissions that would function great with 373's.
If I go with a 700r4, 200r4, or 4l60e, is there any electrical issues that I would have to deal with? Thanks,
![]() Join Date: May 2013
the 2004r in non lockup form is not electric , the 700 4r can allso be built this way , 4l60 is electric , with any of them you are going to have to cut the driveshaft . if you have the trany I suspect you do in the truck now , you will be needing a crossmember allso , 2004r will be the easiest of the bunch to install
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
The 700R4 non electronic version is exactly what you need, you can buy a kit that has everything you need to make it work right.
The only thing you need a transmission shop to do is set the Throttle Valve cable properly. If you want to buy a auto column you can buy them in good condition here on the board super cheap. |
#12 | |
This is a good one to use: http://www.grimmjeeper.com/gears.html |
#13 |
So nice to hear someone not leave out the lonely 2004R, one of my favorites due to it's T-350 length and middle of the road 1st-2nd gear ratios and slightly longer OD as well. Amount of mods to make strong comparable to the 700R4.
